Hi all,
I have for sale our Ford EF XR8. We have had the car for a bit over a year now and was bought mainly for towing my car.
However since we bought it I have only used it once for towing and really have no need for the car anymore (having 4 cars already)
So here is the run down:
FORD EF 1996 XR8 AUTO
White
203,000kms
12 months rego
4 new tyres
New front and rear slotted rotors
New front pads
CD
Air
Power front windows
Power mirrors
Tow bar
Aftermarket headers
Twin stainless exhaust
Since we bought it the following has been replaced in services:
Top rad hose
New leads
Plugs
Battery
Rotor button
Ignition module
CAS
Fuel filter
Also had the front bar professionally repainted.
Has a minor scratch and a slight ding above the rear wheels arch but the paint is in very good condition for its age.
The gearbox looks to have been re-done at one stage by the previous owner as it is remarkably clean.
There is one slight bad point, when cold it will sometimes take a bit to engage 1st but happens only once then it's fine.
Price is $5500 ono.
Pics up soon but interested people can send me a PM for quicker pics.
https://www.sau.com.au/forums/topic/371239-fs-ford-ef-xr8/
  • 1 month later...
  • 4 weeks later...
$3300 THE LOWEST I WILL GO!
Has to sell this month otherwise its off to a used car dealer. Grab a bargain!
Dont ask for pics, if you are interested in buying the car come and have a look at it.
https://www.sau.com.au/forums/topic/371239-fs-ford-ef-xr8/#findComment-6100116
  • 3 weeks later...
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
    • C'mon! At least come kicking and screaming into the 2000s. BA XR8 bulge.
    • No such thing as E30 in Sydney servos As stated above, flex fuel is your only viable,  and "safe" option I believe
