hey guys picked this beast up 2 weeks ago. Made a call with an offer that I couldnt beleive was accepted. Wasnt planning on getting back into cars until our Europe trip was over next Feburary, although it was to good to let go. Plans are to fit nito oil pump for security as I was advise it had forged rods and pistons, new front bar, carbon rear diffuser, drift lip for street & carbon boot lid with a track wing of some sort, rota grid 17x9.5 + 12 rims rear and a general tidy up.
bought the car with:
JE pistons
Spool rods
Ported head
Standard cams
Plazma man plenum
GT3540 .82
6boost manifold
Tial 44mm gate
Splitfire coil packs
z32 afm
3.5" exhaust
Nismo 740 injectors
Alloy radiator
ARE intercooler
ARE sure tank with 044 and walbro lift pump
Apexi pfc
eBoost 2
Tenabe coil overs
Adjustable rear camber arms
All the bolt ons are worth more than what I had paid for the car! Car was taken up to my tuner in Hervey Bay this weekend for a check and quick retune. Rolled in and made 390 on 18psi after some time and alot of fixing the car made 400rwhp on wastegate pressure (16psi). A little more tuning and we cranked out 473.9rwhp on 23psi :). Really really happy with the tune and the car drives beautifully, will be leaving at this level for a little bit and see how it goes around lakeside raceway!
Uploaded with ImageShack.us
https://www.sau.com.au/forums/topic/371254-black-r33-gts-t-streettrack-project/
  • Replies 99
list of things to do:
Ceramic coatManifold
rear housing
wastegate
dump pipe
Piant rocker covers or fit a spare set of rb26 covers not sure my stick with the rb25 covers
Fit -10 fittings to rocker covers
Fit -10 fittings to catch can and run lines
Piant engine bay
Mount HIDs properly
Fit strut brace
Fit turbo beanie or heat shield
Paint lip spoiler
Paint new front bar
Paint 400r side skirts
Repair rust in LHF door and respray
Repair and paint rear bar
Fit Pivot push start button
Fit Greddy oil pressure guage
Fit Greddy oil temp guage
(all made in a custom switch guage panel)
Fit shift light
Fit new Nardi steering wheel & quick release hub
Fit new carbon fabric gear boot & hand brake boot surrounds
Fit new carbon fabric centre consol lid cover
Fit new polycarbonate box for surge tank and pump
looks like ive got a lot on my plate
just a quick update. fitted the pivot push start button, moved the eboost2 to the pillar,fitted 4"intake pipe, painted/fitting duck wing, painted the dash in wrickle paint which came up really good and fitted new gear shift/handbrake boot.
Edited by johnbarry88
So when is it coming home Tony ?
thanks anthony, i'll look him up and you aswell when i make my way up there.
i was up there at easter and saw a nice black r33 boosting past blazes burgerie. wonder if that was you? sounded awsome!!:cheers:
  • 3 weeks later...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I though you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
