  • Replies 99
just a quick update guys.
made/installed:
greddy oil temp
greddy oil pressure
fitted EL guages but found out the the rev gauge was for a gtr so I couldnt put it in :( still looks good.
fuel pump switch
ingnition switch
blocked off bov
made power steer resivoir bracket
dropped one of my new greddy gauges when I was making the plate and put a dent in it but still works :(
  • 3 weeks later...
yeah the power figure was made on a hub dyno with 2deg of timing put in, made 451rwhp 23psi on the same dyno without the timing. Chucked it on the dyno at powercruise and made 440rwhp so thats a power figure loss of 2.5% from hub to roller. Looking at cams injectors and e85 :)
  • 3 weeks later...
hey guys little update. just got my hands on a piar of 19x9 +13 vs-kf's for the front and in the process of finding some 19x10 +18 ish for the rears :) Mind you this is just for the street :P
hey guys little update just fitted a gtr cooler that I swapped for my a.r.e as the end tank were straight and the bar would fit unless I chopped the shit out of it. Also fitted my gtr front bar, series 3 lip should turn up next week sometime and then ill fit my oil cooler :)
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I though you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
