Item Summary: 2003 SUBARU IMPREZA WRX, Special Edition (momo spec)
Postcode: 4077
Odometre: 126,000 kilometres
Asking Price: $21,000
Condition: Used
Reason for Selling: Upgrading
Delivery Methods: PickUp
Contact Info: 0433812776 or Pm
Extra Information:
FOR SALE is my 2003 Subaru WRX Special Edition (MOMO SPEC) 5speed manual. I have owned my rexy for the last 5.5yrs and have never had a single problem with it.
126, xxx k's on the clock, serviced every 5000ks with FULL LOGBOOK HISTORY. No dollars spared on this car from the parts right down to the oils. APC have carried
out some of work includes the mods and services form 100 000ks onwards. Paint and interior are in excellent condition. Has the odd stone chips here and there on the
front bar, and a couple of little marks on the car from ppl opening there car doors and shopping trolleys, but nothing really noticeable.
Mods:
• VF34 5000ks old
• Greddy Turbo Timer
• Greddy V Spec FMIC
• Greddy Front Strut Brace
• Pedders xtreme Fully Adjustable Coilovers and cambers
• Silicone Hoses (turbo induction, radiator)
• GFB Light Weight Pulleys
• 3A Racing Pod Filter
- Turbosmart Dual BOV
• Turbosmart Boost Gauge
• Turbosmart Fuel Regulator
• 550cc Fuel Injectors
• Custom 3.5" Turbo Back exhaust with 7''cannon (sounds really lumpy)
• XHP 19"Chrome Jets on Nankang Tyres
• Walbro 550hp Intank Fuel Pump
• Viper 5000 Car Alarm With GPS
• Brand new clutch done 1000ks
- Whiteline adjustable rear sway bar
Power: Low boost runs on 7 psi and is Safe Tune for high boost at 16psi and ran 198.9kw atw.
At the end of the day dollars has been spent to get this rexy where it is today. Nothing needs to be spent unless you want more power, but at the moment this rexy is quicker than most STI and EVO's around. Rego runs out in December and RWC will be provided upon deposit.
No Deposit NO test drive.
$21000
https://www.sau.com.au/forums/topic/371262-subaru-wrx/
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
