Hey guys,
Whats up, nothing here. I was thinking about buying a Skyline but really havent researched them at all, heck you really dont even see them around here. What is a good car that I can get for say around 20000. Need some advice please. What is the conversion for horsepower to (whatever you guys use). Sorry not to intellegent. Thanks ahead of time.
Trent
https://www.sau.com.au/forums/topic/37128-n00b-question/
Yeah, but dosent really fall into my area of interest. I perfer good cars, and not cars with a 25' exhaust tip!!:) My state is classless, hince no Skylines!! (not really classless plenty of ZO6's etc..) What type of skyline should I look into? I guess looking to spend somewheres around 20K
Trent
https://www.sau.com.au/forums/topic/37128-n00b-question/#findComment-743384
Im not sure of the way it works where you are. Are you looking at importing one from Japan??
If so get in contact with some local workshop's who are eligable to import and comply a car for you this will give you an idea of the cost's involved with the whole process then you can put together a budget, Then how much you can spend on the actual purchase price of the vehicle becomes more apparent.
https://www.sau.com.au/forums/topic/37128-n00b-question/#findComment-743392
1996-1997 Skyline R33 Series 2 , they have a differnt bodykit,wheels,turbo and interior is similar but better. that would be your best option since they would have low "miles;)"
i have a friend who is currently importing a R33 GT-R to the states from osaka .. do you have MSN Messenger so i can tell you more into importing cars into the states etc ?
https://www.sau.com.au/forums/topic/37128-n00b-question/#findComment-743418
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
