Has anyone really wondered why our R30 Skylines slip through the air so well?
Drag, down force, design etc all go to fuel efficiency, but do you know there is only one (1) Nissan with a better drag coefficient (Cd) than the R30 Skyline.
Cheers, D
https://www.sau.com.au/forums/topic/371296-slippery-r30s/
Nobody got any ideas????????
I find this amazing!
Just imagine the McLaren F1 has a worse Cd than the R30!
The R30 has a drag coefficient (Cd) of 0.27
The 2007 GTR has a drag coefficent (Cd) of 0.27
The 2010 GTR has a 1/100th of a point better Cd at 0.26 and is the slipperiest Nissan ever built.
To put this figure into a bit of perspective, the R32 GTR has a Cd of 0.40, the R33 GTR 0.35, 280ZX @ 0.385, 1983 Z31 300ZX has 0.30, 1989 Z32 has 0.32, G37 Infinity coupe has 0.31 and both 350 & 370Z 's 0.30
Cheers, D
https://www.sau.com.au/forums/topic/371296-slippery-r30s/#findComment-5926100
Better than you.LOL
I said RMR, ie, Hatchback. It aint an R30.:pirate:
Humble apologies my dear friend, but my wind tunnel test results don't differenciate between an EDR, KHR, RMR, or any other derivative, because I guess at the end of the day THEY ARE ALL R30's or have I got this wrong to :cheers:
Whilst I'm here does anyone know why the 2010 GTR has a slightly different Cd to it's predecessor?
Cheers, D
https://www.sau.com.au/forums/topic/371296-slippery-r30s/#findComment-5928154
what's the CD for R34 GTR ... i am guessing not very good number
Just off the top of my head I would assume it would be quite reasonable, but I will check on it to confirm, but as the R34 was designed off the R30 I would think it might be quite good as I said.
Cheers, D
https://www.sau.com.au/forums/topic/371296-slippery-r30s/#findComment-5928161
  • 5 months later...
Guys,
The Cd number is relevant, but it's only part of the story...
The actual drag force is calculated by D = Area x Cd x 1/2 * rho * (velocity)**2
rho is the air density and velocity squared is just that, speed mulitplied by itself.
The half rho v squared part will be the same no matter what the vehicle, so the difference in drag force comes down to Cd mulitplied by frontal area.
The McLaren has less frontal area than a Skyline R30 and so it will have a lower total drag force.
cheers,
Howard.
https://www.sau.com.au/forums/topic/371296-slippery-r30s/#findComment-6182904
I hear ya hugh....
I always felt after 160km my old hatch would just nearly roll to 200... (off the dial and then some...)
shit i miss that car...
It will and I do too. Miss it.
https://www.sau.com.au/forums/topic/371296-slippery-r30s/#findComment-6183093
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
