A standard satin black wrap would look way better, the only way a carbon fibre look is cool is if it's actually carbon fibre. I'm guessing he spent all his money on the F40 and only had enough to do a fake carbon wrap and make that ugly little add on wing.
This.
Maybe he did it to protect the OEM paint, which is quite unique in how sparsely and unevenly its applied.
That said, if he wanted to keep the car in Concourse condition he wouldn't be driving it.
maybe he just sanded the paint off the carbon since half the time it is that thin you can see the carbon weave through it, or so they say.
Nah - he just polished it too many times
No. I'm not talking about the car
I reckon it looks fantastic. Wing extension and all.
When you have a car which is that fast, you can paint it/clad it with whatever the hell you want because at the end of the day if people knock you, simply ask them what exotic supercar they drive and would they like a race. Once they respond with silence and the slinking away, you can laugh and go on enjoying your carbon clad car. Of course there are a couple of people on here who could rise to the challenge, but they are in the vast minority.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
