Hey guys,
I'm currently dealing with a fantastic overseas supplier who has offered me a great deal on OEM, Aftermarket Engine parts, Bodykits and MORE!!!
So post up what you want guys! and ill create a list and send it off to get a price!
they do all sorts of body kits too so just post up what you want!
They deal with such guys as Sam at GTMotorsports, Scott at Relentless Autosports, Tony at Motordyne Engineering and many more!
For any over seas orders the supplier has no problems tracking down all the parts and opening other avenues of inventory for you to get you the absolute overall best
price
on your purchases by packaging everything under one shipping label. It does not matter how many boxes we use, shipping companies use overall measurements of all the combined boxes and weight. So dont worry about (Example) your coilover system getting into a fight with your front bumper in the shipping box =P
For any more INFO PM me
https://www.sau.com.au/forums/topic/371305-overseas-order-for-parts/
  • Replies 40
so guys im about to hit them up,
v35 coupe
rear v35 pods
Nismov3 front bar
07 JDM tails
07 JDM Headlights
v35 sedan
y-back exhaust for sedan - 3' megan
v36 Sedan
stillen front spilitter for v36/g37
g37/v36 weathershields
Anyone else?
v35 coupe
rear v35 pods
Nismov3 front bar
07 JDM tails
reverse light switch (unsure on what this is)
OEM brake rotors for brembos
drivers side window motor
tein basic or super street coilovers
OEM Infiniti badging (both on rear boot)
OEM Infiniti Grille Badge
07 JDM Headlights
v35 sedan
v36 Sedan
v36 Coupe
IPL sideskirts
19' Stock wheels
UPDATED LIST SO FAR
Edited by Cobey
Out of the US, had no drama so far, received over $8,000 in stock
customs is watching then.
they will randomly open mine to check things.
given the list you have there I would get a customs number/broker if you are going to keep doing it. gov't will nab you as well if you are not careful.
Hi Cobey
If this is still on, I'd like a few things
2008/2009 v36 sedan
Eibach prokit springs( the ones that drop by approx 1 inch)
Hotchkis sway bars front and rear.
ARK cat back exhaust- not sure if the g37 over there will fit on a v36??
Phillip style DRL -the ones in below link.
http://store.ijdmtoy.com/Philips-Day-Light-LED-Daytime-Running-Lights-DRL-p/led_ddl_sku_7c.htm
cheers
oz.
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
