Well im having trouble moving my stock parts so thought id put these up.
First up a rare 3 point Tomei strut brace to suit R32 GTS-T/GTR, never seen another one for an R32. $200 + post
Rare greddy carbon fibre air diversion plate, suit R32 GT-R/GTS-T (with GTR bonnet), discontinued from greddy. $200 + post
Have an HKS metal intake pipe with pod to suit RB20/RB25 very rare (not pictured), let the ladies hear your dose bro. $200 + post
Cusco castor rods suit S13/180sx/A31/R32 GTS-T, good condition bit dirty thats all. $160 + post
Cusco tension rod bar, suit S13/180sx/R32 GTS-T/A31, good condition stiffen up that front end. $100 + post
R32 factory weathershields, ive sprayed them with the stuff you use to tint your tailights as they had scratches, $200 + post
any questions PM me
located Melbourne Southeast
cheers
Kyle
https://www.sau.com.au/forums/topic/371327-r32-rare-parts/
Hey sorry to hijack a bit.
Quick question about the Tomei strut brace. Did you ever have it mounted on a GTS-t?
I just managed to get my hands on one and wanna know if you have any pics of it mounted? (just where it goes onto the firewall).
Good luck with the sale, awesome parts.
https://www.sau.com.au/forums/topic/371327-r32-rare-parts/#findComment-5919646
theres a plug on the firewall you take out and put a nut and bolt in, to get to the back you gotta take the plastic piece off under your windscreen where the water drains out off your windscreen not to sure what the part is called.
https://www.sau.com.au/forums/topic/371327-r32-rare-parts/#findComment-5919805
  • 2 months later...
  • 5 months later...
  • 3 months later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
