Hey guys,
So im currently doing quite a bit of work to my 34 gt-t and had a couple of questions about the stock gauges and upgrading them as i heard they werent 100% accurate and the standard 1bar boost gauge is useless to me as ill be running 18+ psi soon...
Firstly how big are the gauge faces as im hoping to just put the new gauges into the original cluster, secondly will the wiring match up from the old gauges to the new ones or will i have to replace it and remove the old wires/sensor etc and lastly has anyone put in an after market door pillar cluster if so how hard is the wiring job for that as i really dont want to be drilling holes through the firewall...im probably asking really stupid and obvious questions its just i havent been able to look over anything as my cars off the road with no battery so im not fussed at looking at it just yet until its running plus would rather hear some answers from experience because i want to do it right the first time as i cant stand dodgy jobs or having to guess.
Cheers. Brock
https://www.sau.com.au/forums/topic/371334-r34-gauge-upgrade-help/
These are the Swoosh brand gauges you get off ebay, I just needed to put something in that gave me better readings and did not look as old school, but could not justify spending the money on Defi guages for a daily driver with the plan for occasional track days...
Cheers for the help guys, knowing the sizing has helped a lot...just one problem is i was probably going with the glow shift elite 10 colour gauges and its going to be a little difficult pressing the buttons on the gauges when theyre hidden away in a cluster haha...hopefully ill spring some brilliant idea...if not im going to have to pay the extra and go with my original plan of the HDI gauges http://www.performance-wise.com/userimages/HDI/GAUGES%20SMALL.jpg
How accurate are they ? Any complaints
Most stepper motor after market gauges are very accurate. The days of using defi and only Defi are over. Defi are a very good gauge, but generally overpriced considering you can get ebay ones for $50-100 with the sensor.
I have fitted 60mm gauges keeping the original plastic off the triple cluster, the only thing I did was use car tint across it so its all blacked out when the car is off..
http://img15.imagesh...7/img2935zd.jpg
Hey mate,
Can you quickly run through what it took to make these fit etc?? Were they are direct fit or were mods required? The factory guages are useless in terms of the readings........
PM me if you can :cheers:
  • 2 months later...
Hey mate,
I would also like to get this info, as i'm looking to replace my factory boost gauge. Ideally would like something that can use the existing wiring, any help?
    • Change the subframe bushes, transforms the car.
    • For something a little more serious, Davinci Resolve is about the best there is for free video editors. No expiration dates or watermarks, completely free.
    • Well, it's taken me until the last week of 2024 to actually do something on the Skyline but I consider it a good head start to 2025's efforts! I managed to justify (to myself anyway...) my purchase of the lift table. It made taking the rear subframe out a lot easier than it would have been without anyway! Everything is out and stripped down ready for a clean then powdercoating.  She's pretty grubby under there but pretty good condition for a 38 year old Japanese tin bucket. 12 years of zero street time have obviously helped that... I need to decide which of the factory suspension arms I will keep and replace so I only get what I'm keeping powdercoated.  Baby steps but it's a start!
    • Turbo gods, some assistance and recommendations please I'm looking into a turbo kit for my 2.5 from MX5 Mania >>>>> https://mx5mania.com.au/products/copy-of-mx-5-nc-2-5-litre-engine-conversion-turbo-2005-2013 Power wise I would like about 200kw atw, and of course dose noises, apparently if you keep a stock 2.5 under around 200kwatw the engine and drivetrain will not hate life even when ragging on it a bit Max RPM on the 2.5 is around 6500rpm The turbo MX5 use is something around the disco potato size as  packaging room for the turbo is pretty limited, which will, I believe, give me my power goals I want and not have the turbo either under, or oversized, but the rear housing bit is confusing  It comes with either a 0.64 or 0.86 From my understanding, which so far is based off googling, so make of that what you will 0.64: spools faster = good Makes more EGT heat on boost = bad Less topend power than 0.86 = I'm only looking for 200 atw so that point may be mute????, I don't know, hence my questions  0.86: Spools a "little" slower = how much slower??? remembering 6500 is my max rpm Makes less EGT heat = good Makes a little more power up top = again, power goals is only around 200 Also, this is a street car, so there will not really be any long track sessions, in saying this I would want it so it was happy with at least 3 hot laps at Wakefield Park if the need arises  I already have a fancy pants triple pass radiator, and a oil cooler with thermostat will be getting installed as well Thanks for any information or recommendations you have 👍, and of course, the comments about me wasting money on drive in drive out modifications, or any other snide remarks about my manhood for owning a MX5 🤣
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
