Hi guys,
I have searched a few times under a few different variations of heading and found nothing. All i need to do is remove my afm plug from the factory wiring and replace it with a newer better one. I was expecting the grey plasic plug to be half moulded and clipped together but it's a solid piece with a yellow insert. Am I right in assuming this Yellow insert is the key and if I remove that then the wiring will be able to come out freely? How do u do it without breaking it? The newer plug is second hand with a bit of wiring hanging out but would rather replace the lot rather than cut wires and solder then tape up.
Thanks in advance
Liam
https://www.sau.com.au/forums/topic/371345-changing-the-afm-plug-over/
A pic might help, there are lots of different plugs around.
Usually you squeeze the two sides in and it should pop out, the yellow part is the inner part of the plug, it also has an outside grey part over it.
When i got mine it was twisted together and then taped up!!!
Hi guys,
Thanks in advance
Liam
You are going to have to make the electrical joins at some point; while it's possible to disassemble the plug and
connect the pins to the wires, you will probably get a better result from doing what you prefer not to
(i.e. join where the breaks are with solder and heatshrink).
Cheers,
SW
Geeze its not rocket science.....
Those plugs can easily be disassembeled , you just need a few precision srew drivers to get in there.....bear in mind however some of them can be very brittle and dont matter what you do, it will break, so you better hope your replacement is in good nick.
Yes the yellow piece is what locks everything in place ,remove that first....
Experiment on the one you have to replace
The whole reason I am asking was because I have never done it or even attempted it before and I don't want to break them. Precision screw drivers? Is the yellow piece clipped in? Screwed in? Just sitting there? Again just how does the yellow piece come out? Thanks for the info but I'm none the wiser as to disassembling it.
Use a flat and pry up in the middle of the front....the whole portion needs to be lifted as you would see three tabs holding the yellow piece from coming out
While you are prying the front get a next small flat and place it in the back of the yellow piece from behind and push it out....try to do it evenly and you will need someone to hold it steady for you
When you get out the yellow piece there are three individual tabs holding each wire terminal in place
Pry these down while holding the wire from behind and pulling it out at the same time .....these need to be moved a good bit for it to come loose.
Waallllaaaaa....
Now reverse the whole process and lets head for the bar
then just fit some new plugs
PC computers usually have good connectors to suit this type of application with locking tabs
check out places like jaycar etc online to find a pair of male/female clips with a locking tab
    • I went from stupid 600+HP setup, to an NA Barra in mine...
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
