Hi guys,
I have searched a few times under a few different variations of heading and found nothing. All i need to do is remove my afm plug from the factory wiring and replace it with a newer better one. I was expecting the grey plasic plug to be half moulded and clipped together but it's a solid piece with a yellow insert. Am I right in assuming this Yellow insert is the key and if I remove that then the wiring will be able to come out freely? How do u do it without breaking it? The newer plug is second hand with a bit of wiring hanging out but would rather replace the lot rather than cut wires and solder then tape up.
Thanks in advance
Liam
https://www.sau.com.au/forums/topic/371345-changing-the-afm-plug-over/
A pic might help, there are lots of different plugs around.
Usually you squeeze the two sides in and it should pop out, the yellow part is the inner part of the plug, it also has an outside grey part over it.
When i got mine it was twisted together and then taped up!!!
Hi guys,
Thanks in advance
Liam
You are going to have to make the electrical joins at some point; while it's possible to disassemble the plug and
connect the pins to the wires, you will probably get a better result from doing what you prefer not to
(i.e. join where the breaks are with solder and heatshrink).
Cheers,
SW
Geeze its not rocket science.....
Those plugs can easily be disassembeled , you just need a few precision srew drivers to get in there.....bear in mind however some of them can be very brittle and dont matter what you do, it will break, so you better hope your replacement is in good nick.
Yes the yellow piece is what locks everything in place ,remove that first....
Experiment on the one you have to replace
The whole reason I am asking was because I have never done it or even attempted it before and I don't want to break them. Precision screw drivers? Is the yellow piece clipped in? Screwed in? Just sitting there? Again just how does the yellow piece come out? Thanks for the info but I'm none the wiser as to disassembling it.
Use a flat and pry up in the middle of the front....the whole portion needs to be lifted as you would see three tabs holding the yellow piece from coming out
While you are prying the front get a next small flat and place it in the back of the yellow piece from behind and push it out....try to do it evenly and you will need someone to hold it steady for you
When you get out the yellow piece there are three individual tabs holding each wire terminal in place
Pry these down while holding the wire from behind and pulling it out at the same time .....these need to be moved a good bit for it to come loose.
Waallllaaaaa....
Now reverse the whole process and lets head for the bar
then just fit some new plugs
PC computers usually have good connectors to suit this type of application with locking tabs
check out places like jaycar etc online to find a pair of male/female clips with a locking tab
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
