Ladies and Gents,
I am slling my beloved S15.. urgent sale..!
I have seen a BMW 1 Series i really like and want to buy.. so my s15 has to go, it has been a good car to me..
Aus Spec Spec R
95000 Km's
I am not the first owner but while i have had it it has never been boosted max i see is 10-12 Psi
It has a GT Spec Saber Front mount intercooler painted Black and all pipeing painted gloss black for the stock look
Rocker cover painted gloss black
Fuse box and air box painted black to match..
3inch full exhaust
dump pipe
mid muffler
rear muffler with very tame twin tips looks almost stock
Never been picked on by police.. very tidy
The car is lowered
Gun metal grey very similar to the color of the car silverish..
Brand new tires on all four courners
OEM JDM Pillar mount with gauge
Sun Roof.. etc etc..
The car will come with standard s15 wheels but we can work something out if you want the rays engineering wheels left on the car..
There is a scratch here and there but i have used it as a daily driver and enjoy driving my car..
It drives very well with no problems..
Recently serviced at Pulse Racing
Plugs
Brakepads front and back
engine oil
oilfilter
gearbox oil
diff oil
$15000, -
Hurry .. ! CHEAP..!
Campbelltown NSW area
0421377199
http://www.nissansilvia.com/forums/uploads/monthly_06_2011/post-60757-13092305687795_thumb.jpg
http://www.nissansilvia.com/forums/uploads/monthly_06_2011/post-60757-13092306466115_thumb.jpg
http://www.nissansilvia.com/forums/uploads/monthly_07_2011/post-20997-13110415047714_thumb.jpg
https://www.sau.com.au/forums/topic/371421-s15-urgent-sale-15000/
it is a 3 inch all the way through with a cat, mid muffler and rear muffler, the exit from the rear muffler (stainless) is also 3 inch but then collects into the two smaller tips i think 2 inch or so, it still has some noise to it but not very loud.
whats the difference between aus spec and jap spec?? Im after a jap spec
JDM has:
- no factory immobiliser
- CAS ECU pins are switched around
- ECU runs a tad more timing (nothing fancy)
- contains more rust,
- has climate control
- and rear wiper!
Rumours say it has a better turbo, but there has never been pictures of the two next to each other for comparison (external & internally) also people say Jap Spec uses 480cc (that's garbage) all S15 Manuals use 450 CC injectors.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
