In a GTT its one of the easiest jobs you can do....
Buy a decent lock bar, remove the shi77y hicas by unplugging it all and taking the tie rod ends out of the hicas, then unbolt it and throw it at ya neighbours cat as that's all they are good for :rofl2:
Just make sure when you bolt it all back up you get it wheel aligned as mine moved from the factory position, also make sure you plug the wiring for the ABS again and cable tie it all back up... Pop the globe out from behind the dash cluster otherwise it will shit you!!!
Thanks a lot for the info mate, really keen on getting rid of it...its caused me nothing but annoyance
Especially when my car decides to lose traction at high speeds and the hicas makes it difficult to correct from oversteering the back more than needed, its honestly unsafe from my point of view
Sounds all easy enough to deal with so as soon as my new turbos fitted and the cars back in running order ill get straight onto it...ill be sure to give the neighbors cat a scare too biggrin.gif
Thanks again,
Brock
Just be aware of the potential engineering/insurance implications; From what I understand it's seen as removing a 'safety device' and needs to be engineered. Quite a few in Adelaide have been caught out on this one.
It should be relatively cheap/easy to get this modification engineered if required. The risk is up to you (and probably depends on where you live).
In most situations where HICAS is acting up, it tends to be because something is worn (HICAS racks are kwown to get 'slop' in them), incorrectly aligned (steering wheel angle sensor) or not operating correctly (dead caps in the HICAS ECU).
  • 10 months later...
Fun and games ... I got an NZ warrant failure on the R34 HICAS tie rod ball joints(outer) being stuffed, the only source for those is Nissan agent ( the people in robbery masks). The parts have a curve in them to maintain a straight line along the tie rod to the wheel stump that fits the tie rod
To hard fix the rear wheels it would be an idea to have wheel alignment adjustment in the lock bar arrangement ?
Any chance of a photo of the mod :rolleyes:
I wonder if the failure was helped by the 200 metre country gravel driveway that is down to the bumpy scalps base, its like cobbles.
Edited by jonakiwi
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
