Guys
I'm on the hunt for some ID2000 injectors and am being told different things by different shops. Coming here to hopefully clear it up.
this is what i've been told...
Injector Dynamics don't manufacture injectors they flow test and report injectors and publish results that are inflated. This is due to using Petrol as testing fluid, rather than calibration fluid that the manufacturers use.
Bosch is the manufacturer of these units and this injectors great success comes all down to Bosch being the current market leaders with injector technologies.
We (powerflow performance) offer the same or some customers say, a better level of service and product quality to the ID products.
All fuel injectors sold by Powerflow Performance, undergo flow testing and packed into matched sets within a maximum of 2% variation. *Note* 1680, 2000 & 2200cc injectors matched tolerances of up to 5%.
so...is this true or false?
And who here has any experience with powerflow performance in melbourne? if yes, good or bad?
thanks
https://www.sau.com.au/forums/topic/371443-id-injectors/
Of course the sales rep is going to say their product is better
I use genuine ID2000's and the car idles and drives like factory.
I used a local injector (wont say name) previously and it was terrible.
Well worth spending the coin on the proper gear and not trying to save a few dollars when it comes to injectors.
https://www.sau.com.au/forums/topic/371443-id-injectors/#findComment-5921456
Guys
thanks
Powerflow is VPW and they are a fantastic company but to rubbish ID's is just crazy, it shows a lack of understanding on their behalf.... maybe too many carby guys there.
Out of all the injectors ive used over the years the ID's really do perform as per expectations... im happy to pay extra for matched sets..... my egt results confirm it.
btw 5% of 2200 is a whopping 110cc......
https://www.sau.com.au/forums/topic/371443-id-injectors/#findComment-5921502
By local injector, do you mean a locally supplied or locally made/highflowed injector?
If locally supplied, was that also a flow matched bosch?
https://www.sau.com.au/forums/topic/371443-id-injectors/#findComment-5921524
Retail is only $750 with adaptors for the ID1000's and $1050 for the ID2000's. Any more than that and you're paying too much
I know theyre the same injector, but are you talking about ID2000's or standard bosch 2200cc EV14's straight out of the packet?
https://www.sau.com.au/forums/topic/371443-id-injectors/#findComment-5923943
injector dynamics modify the existing bosch ev14 injector with there own nozel. because they are a ball type injector this is posible. (not a pintle and seat.)
The bosch and ID injectors are identical. Injector dynamics take a bosch injector, put their pretty nozel on the end (which makes no difference to the spray pattern), machine off the last 3 digits of the part number and flow and dead time test each batch.
When you buy a bosch injector locally, you get the same bosch injector, last three digits of the part number are machined off (to protect bosch) and they are flow tested etc.
I know if I had the choice, I'd be going genuine Bosch, unmodified and exactly how they were intended. They flow the same anyway and the price is better. Win/win
https://www.sau.com.au/forums/topic/371443-id-injectors/#findComment-5925276
    • Late to this party but here is your go to shop in perth - https://www.facebook.com/gsautoworksau GTSBOY is on the money cost wise, drive in and out will cost you 15-30k or more.    Some items that will save you money  - plug in link ecu g4x is much cheaper than haltech.   -Pulsar turbo, seem to be "OK" now, never used one myself You really don't have to build the motor, E85, headgasket, studs and a good RB26 will live for ever.    Swapping over the twins won't save much as you still need ecu, tune, fuel system etc.
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
