Yeah, but as I've told you before, they don't have these tables in Nissan ECUs. Only the RB26 even has an inlet air temp sensor. The whole point of my post was that you have to work with what you've got. In the case of Nistune, it means that the knock maps are not always reliable, so you have to decide if you're going to try to live with random changes of map (when it shouldn't), or it never changing because it never detects knock even when it happens (which also occurs, and is of course worse) or whether you're going to disable it and tune sensibly to avoid the problem altogether. It is possible to tune so that you might miss out on some winter performance, but you won't ping it to death in summer.
Burnouts are dumb at the best of times. So I say that motors that cook as a result are not a problem, just an education.
nistune has coolant temp trim tables.
but yeah do what you said re just tuning for summer and itll be fine all year
Random changes....sounds a bit disconcerting for a daily driven car.
If I do go for a nistune/PFC the closest tuner will be nearly 2 hours away, which makes me think any drama's will be a big hassle for me.
There's no reason to be stressed about it. Once tuned, a nistuned ECU should be able to be left alone until you change something on the engine. Mine hasn't been hooked back up to the laptop since it was tuned years ago (apart from just to have a look at something.)
ok, cool. Well I am pretty much sold on the nistune, seems to be the best bang for buck option. And it seems they don't make PowerFC's anymore (not that it really matters).
What is the going rate for a nistune....tune?
guess i'll have to trawl through the QLD site to find some reputable tuners who are nistune friendly. Do I NEED a z32 or is just optional/better than the stock AFM?
And final question (I hope) - I have come across a 2nd hand ecu with nistune already installed, if I were to buy this would it be a simple plug and play and then getting it tuned to my mods?
Thanks again, you guys have been very helpful :cheers:
It has a resolution suited to higher airflow, so if you max out the stock one (~240kw ish) then you need a Z32 or it makes tuning very difficult.
Re the ECU no it isn't that simple, you cant just plug an R32 ECU into an R33, you need to wire it in.
Edited by Rolls
So my stock AFM should be fine for the ~200 mark? The ecu/nistune i'm looking at is out of an R34....
EFI do Nistune in QLD and the tuner sean is great, I had my R32 Nistuned by them it never missed a beat as long as I owned it.
I went a Power FC in my R34 GT-T and it's working great, I have had it installed since the car had it's first mods fitted, No issues with the unit what so ever.
Edited by RandomHero83
Rolls , what makes u think u have to wire in an r32 ecu to a 33?
Rolls only the VTC needs to be wired in on gtst's. But if u buy a programmed r32 ecu that has rb20 image u will have to either change the tps to a rb20 tps or send the board to NIStune to get a rb25 base image programmed.
On GTR as EAT ME posted, change a few settings in NIStune
That is right, I had to use a S1 rb25det TPS as the S2 one didn't work with the R32 ecu.
So yeah you have to "wire in" a few things, not very difficult though, but if you aren't electrically useful then you would need to pay someone to do it.
    • This might be true if you live in NZ but I can't see how this could be true for us locals here.  I've found the customer support for Haltech to be absolutely amazing. I've turned up to Haltech and spent entire days with their tech support guys, they've even helped me with wiring dramas that had nothing to do with their products.  They have the best customer support of any company I've dealt with, I can't imagine how my experiences with them could possibly be any better.
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
    • Right, but I thought the problem has been for a while now that even if you know manifold pressure + throttle position you still have non-linearity and aliasing issues vs actual engine load? One way I can see things simplifying is going DBW, then all air going into the engine is represented by the throttle position. As opposed to a random bimetallic strip vaguely linked to engine temperature opening and closing a shutter or some random power steering air valve suddenly allowing a bunch of bypass air. But the same throttle position/RPM at ~atmospheric MAP in different gears is not guaranteed to be same engine load? Honestly, ITBs are of such dubious value IMO. I don't know why these things are hyped up so much. The main benefit as far as I can tell is you reduce the likelihood of cross-cylinder EGR scavenging with significant cam overlap at idle. I would absolutely run speed density and be done with it if not for this fairly esoteric control problem.
    • Hah dont worry, my adult brain has this conversation every single day. Dont waste your money, invest more of it into shares, pay down the mortgage. Then the bedtime insta doom scrolling begins and after being bombarded with gtr's my mind is set: im definitely getting one! I have the current model mx5 as the weekender, but i just miss my boost and literally like your username, the sututu's that come with it. I remember with my 2nd supra, as it had twins and vvti, they used to spool real early, like 1,500rpm so you could just be a spooly boy all day long. Some people say they get over it after a while, not me tho.
