We can produce both powers at the same rev by adjusting the throttle plate.
Timing would be correct for the application at both loads.
If the AFR is the same fuel usage will be double.
However, I do believe I was caught up in the moment and using the word "exactly" may not bet totally correct.
There are many factors that come in to play like the difference in barometric pressure, air and fuel temp from the 2 events being 100hp and 200hp.
If measurable there would have to be some sort of variation.
The real concern is why your turbo is kicking out? I would be upset if my 3037 was doing that
More revs means more inefficiencies due to friction in all the moving parts, different revs mean different intake speeds due to the cam (which is why torque changes and isn't always the same) on boost, off boost changes things as well. The same power at the same AFR can be COMPLETELY different.
Torque changes through the rev range due to changing Volumetric Efficiency.
i dont get whats so "lol", you do realise that its a street turbo usually you dont go over 5000rpm, i can deal with the 500rpm unlike having a lot of lag.
A street turbo that comes on @ 4500rpm - when you don't go over 5000rpm?
500rpm band... awesome.
Let's not forget more RPM when connected to a gear = more vehicle speed = more resistance = greater load on the engine to maintain that speed...will change with inclines and declines of road surface too. Way too many variables!
Lol. On drugs much? Who says you don't usually go over 5k in a street turbo car. Especially wierd when we're talking about RB engines where you can scream to well over 5k in less than a second in 1st and 2nd....and usually do so.
I do believe i said the same revs for different power.
You should actually read my post before replying.
im running a GTX3076r soon so i dont really care i never take it on track so below 5000rpm is good enough beside if i tune that badboy properly i can achieve about 480hp which is very decent for a street car. Another mans eat is another mans poison.
What uses completely more fuel.
An Ls1 5.7 NA at 12.5:1 making 370rwhp
Or a CA18 turbo at 12.5:1 making 370rwhp?
Now we are talking massive measurable differences here so the answer should be very clear.
I have no idea, would come down to many factors... valve train friction, the v8 has more valves, pushrods, but each piston is lighter, the turbo car has higher VE but less cylinders.... Id flip a coin imo.
Probably go the LS1 because of more conservative cam profiles/emissions laws when the motor came out.
Edited by Rolls
but the LS1 has more volume, and needs less load per liter to create the the same power.
In a perfect world would have a smaller throttle opening but generate the same power.
So you can tell me, on the same engine creating 2 different power out puts that fuel requirements per horsepower are COMPLETELY different
But you cant tell me that with 2 completely different engines, creating the same horsepower your not to sure what one would use more fuel?
I'm not sure if this is a serious question? How on earth am I meant to know the different efficiencies of the two engines? It involves hundreds of things! All I said is it would be different...
Its not a serious question, Its a trick question. Its also a demonstration to show that statements like the above shouldn't be posted unless you know exactly what you are talking about.
Both engines use the similar fuel. most would say the same fuel. both do it in COMPLETELY different ways.....
But both use very similar fuel quantities.
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
