I found the attached dyno, it's different boost levels with VTC on or completely off.
VTC is switched at around 4700
I have no dyno with VTC switched on all the time, sorry!
The graphs shows torque only.
Edited by Torques
AFAIK the inlet cam is advanced by around 18 degrees.
This gives the charge more time to fill the cylinder, especially at lower boost this might be helpful.
However this measure also increases valve overlap which leads to charge reversion.
Turbo engines usually have very tame camshafts anything 'wild' or overlap is no good since the back-pressure in the cylinder is reversing through the inlet.
(Of course there are many different turbo engines ...)
I think some people don't understand what VCT is actually doing..
Edited by Torques
:yes:
But I believe it advances it an even 20deg.
My comment wasn't directed at anyone in particular but more so at the generic comments of "leave it on all the time".
I know when it is enabled at idle in my car the idle is far from smooth but could probably be tuned smooth. If left on in the high rpm range my set of the pants dyno tells me it has lost power.
It also makes a huge difference in the midrange, particularly with a bigger turbo and helping it get on boost (even more particularly because my car is auto with the standard stall speed).
Jez, if you get your setup working with the VCT on all the time below 'X' rpm, will that affect overrun running? i.e. trying to get my head around how the engine will respond on decel with the intake cam advanced 20deg :blink:
I had vct permanently on for a few days while my ecu was being modified ( chipped R32 ecu piggy backed on to my Stagea ecu) . Idle was not so flash and I knew that I was losing a bit of power at the top end (over 5000 roughly) - so its driveable but not recommended .
Yes, the overlap of the camshafts is no good for low rpm / idle.
The exhaust gases revert into the inlet ..
That's why the Z32 ECU only switches to 'on' at
higer rpm > 2000
a minmum speed
car in gear
It advances the intake cam, this decreases overlap increasing the intake velocity at low rpm removing reversion but causes a restriction in the top end, surely this would make the idle better not worse, eg it is the opposite of putting a big cam in?
:yes:
Found it.......
Green(tq) / black(hp) = stock ecu 10psi nvcs off (huge dip due to R&R)
Dark blue(tq) / Red(hp) = Tuned ecu 10 psi nvcs on from 1500rpm right up ( notice how it shits itself after 5000rpm)
Orange(tq) / Light Blue(hp) = Tuned ecu 10 psi nvcs off
..so for reference from the graph at 3000rpm it makes about 10hp and 17 ft-lbs more when nvcs is activated
Edited by Don Dada
Overlap = Time Inlet and Exh\aust Valves are open at the same time, so when you open the inlet earlier overlap is increased.
Larger ovelap is in general not helpful to idle.
At low rpm overlap also causes the intake charge to be sucked out of the exhaust due to the relatively long time the exhaust side is open with regards to rpm.
Very nice,
Would you have this a bit larger please (it's stamp size)
Found it.......
Opens later, not sooner.
Advancing intake cam means it overlaps more, retarding exhaust cam means it overlaps more. Think of advancing as turning clockwise and visualising the cam profiles.
edit:
good explanation here
http://www.dsmtuners.com/forums/articles-engine-fuel/221200-cam-basics.html
Edited by Rolls
You guys need to re- Read what advancing a cam does
Increasing overlap increases cylinder filling at high rpm
So why would you want that when trying to increase bottom end mid range torque
Advancing the intake cam means that it closes earlier than when set at zero.
Hence decreasing the amount of time both intake and exhaust valves are open I.e overlap
Advancing the exhaust cam increases overlap as does retarding the inlet cam
It isn't that simple, you can change the amount of overlap, but also the where in the filling cycle the overlap occurs.
it is the opposite to that.
I've always been told different to that....:/
Eg advancing the cam is turning it the same direction as the crank rotation
Eg http://www.compcams.com/technical/FAQ/LSAproperties.asp
In the case uou are describing the 25s VCt must retard the cam as having huge overlap on a small motor is a sure fire way to lose all bottom end grunt
As you say Not that simple but a good rule of thumb
It is very very simple.  Stop thinking about everything else and start fresh.
1) Overlap is the time when the exhaust valve is closing and the inlet valve is opening.  Inlet valve closure has nothing to do with it.  Only opening.
2) Advancing the inlet cam will of course make it open earlier.  This will increase overlap.
VTC is active between 1500-4700 (or thereabouts, depending on what ebgine we're talking about).  Make your own conclusions about whether it is advanced or retarded by the actuator.
Edited by GTSBoy
Zebra, think about the order of the strokes,
Your thinking that the exhaust stroke happens after the intake stroke (which it does, eventually) so if your advance the intake cam timing your moving it away from the exhaust stroke, but the exhaust stroke is immediately before the intake stroke so advancing the intake timing moves it further into the ending exhaust stroke. The intake stroke has compression and power before you get back to exhaust.
Edited by D_Stirls
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
