We can produce both powers at the same rev by adjusting the throttle plate.
Timing would be correct for the application at both loads.
If the AFR is the same fuel usage will be double.
However, I do believe I was caught up in the moment and using the word "exactly" may not bet totally correct.
There are many factors that come in to play like the difference in barometric pressure, air and fuel temp from the 2 events being 100hp and 200hp.
If measurable there would have to be some sort of variation.
The real concern is why your turbo is kicking out? I would be upset if my 3037 was doing that
More revs means more inefficiencies due to friction in all the moving parts, different revs mean different intake speeds due to the cam (which is why torque changes and isn't always the same) on boost, off boost changes things as well. The same power at the same AFR can be COMPLETELY different.
Torque changes through the rev range due to changing Volumetric Efficiency.
i dont get whats so "lol", you do realise that its a street turbo usually you dont go over 5000rpm, i can deal with the 500rpm unlike having a lot of lag.
A street turbo that comes on @ 4500rpm - when you don't go over 5000rpm?
500rpm band... awesome.
Let's not forget more RPM when connected to a gear = more vehicle speed = more resistance = greater load on the engine to maintain that speed...will change with inclines and declines of road surface too. Way too many variables!
Lol. On drugs much? Who says you don't usually go over 5k in a street turbo car. Especially wierd when we're talking about RB engines where you can scream to well over 5k in less than a second in 1st and 2nd....and usually do so.
I do believe i said the same revs for different power.
You should actually read my post before replying.
im running a GTX3076r soon so i dont really care i never take it on track so below 5000rpm is good enough beside if i tune that badboy properly i can achieve about 480hp which is very decent for a street car. Another mans eat is another mans poison.
What uses completely more fuel.
An Ls1 5.7 NA at 12.5:1 making 370rwhp
Or a CA18 turbo at 12.5:1 making 370rwhp?
Now we are talking massive measurable differences here so the answer should be very clear.
I have no idea, would come down to many factors... valve train friction, the v8 has more valves, pushrods, but each piston is lighter, the turbo car has higher VE but less cylinders.... Id flip a coin imo.
Probably go the LS1 because of more conservative cam profiles/emissions laws when the motor came out.
Edited by Rolls
but the LS1 has more volume, and needs less load per liter to create the the same power.
In a perfect world would have a smaller throttle opening but generate the same power.
So you can tell me, on the same engine creating 2 different power out puts that fuel requirements per horsepower are COMPLETELY different
But you cant tell me that with 2 completely different engines, creating the same horsepower your not to sure what one would use more fuel?
I'm not sure if this is a serious question? How on earth am I meant to know the different efficiencies of the two engines? It involves hundreds of things! All I said is it would be different...
Its not a serious question, Its a trick question. Its also a demonstration to show that statements like the above shouldn't be posted unless you know exactly what you are talking about.
Both engines use the similar fuel. most would say the same fuel. both do it in COMPLETELY different ways.....
But both use very similar fuel quantities.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
