Got a greddy oil cooler to suit RB engines, has filter relocator with built in thermostat, all lines included and massive 14 row core. $550
Greedy 100mm thick intercooler core, painted black for stealth, some bent fins, $400
Located in Adelaide
Contact via pm or txt on 0430133943
https://www.sau.com.au/forums/topic/371483-greddy-cooling-sa/
