*Are you sure about that lol There isnt only one GTR mechanic in Sydney mate, lots of us on here have done it for a living*
I'm well aware of this fact as I rang about 5 different workshops before opting with Dart and funny enough, Advan where you say you were, were one place who said I could well get high 200's to 300kw with stock turbos and the mods I have so I'm not sure why there is so much doubt in the power figure?
  • Replies 69
Posted Images
well I guess everyone is entitled to they're opinions but I'm happy with the way the car is. Jims dyno is apparently de-tuned 20 kw for race cars or something so power readings are 20kw less on paper than actual power figure. So car On paper was 199kw before and 261kw after but Jim said actual power is about 280kw. Totally different car to drive and big difference In power. I can definatly feel the increase and was told car could have been pushed even further but he kept it safe. The power figures are on paper And I will post them soon. I'm not saying anyone's opinions or suggestions are wrong. I'm happy with the car and Jim definatly seems to know what he's talking about and doing so I have faith in his work aswell as researching positive feedback from others who have used dart before I went there.
199 to 261 sound spot that's about the results we see, i prefer to run a little less boost but it depends on the car and the owners wishes.
great result and great car... the R34 GTR still attracts so much attention.
(all of the std turbo'd 34 gtr's we have done i generally see 195 to 210)
you've done everything correct in my opinion. trust your tuner, take advice from others, question the tuner if you are unsure, etc. glad you are happy with the car! any pics or videos to share?
Thanks for the positive comment STATUS. Definatly still a great car for they're age in both drivability, performance and looks in my opinion. I'd definatly rather spend 45-$50000 on one over a new SS commodore or something.
The way you and others are talking though its like we dont know what we are talking about. Because we are behind a keyboard we know nothing, we must just be keyboard warriors who have only ever built cars on GT5 which is far from the truth. I worked at Advan for 4.5 years and built countless GTR's. Street cars, time attack cars, drag cars, show cars etc I have seen the results of what 1.15 bar of boost does to ceramic wheels.
We dont doubt the power figures, we doubt the longevity of the turbo's at those boost levels. An R34 GTR will happily make that power, but for how long
I think we have all made our point and your happy with the car so thats the main thing.
NOW ya tell us all after pickin the arse out of this entire thread stupid.gif.
I haven't once said or implied yous don't know what yous are talking about. If anything its you who was talking as though I don't realise there's more than one gtr tuner in Sydney or Jim/Dart don't know they are talking about. If you look back I actually thanked everyone for they're comments, suggestions and input. I can't control the others opinions on here as Unfortunatly I'm not God. they made there opinions or thoughts just as you did yours. I don't doubt you worked at advan for 4.5 years and do know quite a lot about these things and if you know know Jim well like you said then give him a call and ask him yourself why he did what he did as I am far from clued up on the technical side.
That is the main thing and the reason I started this thread in the first place. Happy with the car and happy with the job. End of story
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
