Front Suspentions Monds Lca's /tierod Ends / Caster Rods
The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past. @joshuaho96 If you want it done right, do it yourself. -
I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
I wonder if these would be discounted when they have their big sales? because if so would be a great time to actually buy them could even end up cheaper than buying from quickjack in the end.
Which grit sand paper did you use on the pulley btw? Thought I'd ask so I don't scratch it up too much
