Selling my helicopter. Its an EXI and its a 500 size helicopter with all quality electronics
Quality design, will fly 3d no problems as it has all the supporting modifications and power
Only flown a few times, flys great.
You would need to install the receiver (already been through bind process with transmitter) and setup the transmitter to your liking and your off
No batteries included, you will require a 6 cell LiPo 22.2v for the helicopter
Its all in perfect condition, all assembled and ready to go! Mint condition as new
99% of ALIGN TREX parts are interchangeable with this helicopter
Its an exact clone of an ALIGN TREX 500, I even used the TREX 500 manual to assemble this helicopter
Helicopter specifications
Length: 850mm
Height: 310mm
Main Blade Length: 425mm
Main Rotor Diameter: 970mm
Tail Rotor Diameter: 200mm
Motor Drive Gear: 12T/13T
Main Drive Gear: 162T
Autorotation Tail Drive Gear: 145T
Tail Drive Gear: 31T
Drive Gear Ratio: 1:13.5:4.68/1:12.46:4.68
Weight(w/o power system): 935g
Flying Weight: Approx 1700g
Complete CNC machined head
Complete carbon fibre frame
Carbon fibre & metal tail servo holder
Carbon fibre boom braces
Metal tail box
Metal tail blade grips
Metal front boom holder
Metal washout arms
Lightweight paddles
13t hardend steel pinion
Painted fibreglass canopy
Electronics
Turnigy Typhoon 500H 1800kv
Turnigy MG930 Digital Metal Gear Servo 3.6kg
TURNIGY Plush 80A w/ UBEC Speed Controller
500 Size Carbon Fiber helicopter blades 430mm
401B AVCS Digital Head Lock Gyro
6s battery monitor
TX/RX
Exceed 6 channel 2.4ghz TX
Exceed 6 channel 2.4ghz RX x 2
Exceed TX software (reprogram/setup TX through PC)
Exceed TX USB cable
$450 for all of the above
PM or call/SMS 0416 623 381
Melbourne, South East
Can post at buyers expense, would prefer pick up
https://www.sau.com.au/forums/topic/371580-24ghz-rc-helicopter-bargain/
How are your 3D skills? :P
Nice heli, I'd be keen but I'd only flown coaxials before. Would you be interested to trade + cash my way for a full 1/8 truggy racing set up?
Non existant :blush:
I've setup my smaller one up for 3d and have flicked the switch but have never been confident enough to actually rotate the heli
You wil find the smaller size, the 450 that I'm selling much easier to learn on because you can learn to hover it in a double garage or somewhere similar and if you do happen to crash it or break something its quiet cheap to replace parts
Up to you! PM me and we might be able to work something out
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
