How do you explain to RTA about the speedo readings being different out of curiosity??
If you want to find more info out, search the forums, dont chat in here. Im sure the RTA has no problem with your speedo showing 300 instead of 180... As you will notice most australian cars show over 180 on their speedo.
Nismo R33 GTR 320km/h white faced cluster with 39,852kms. It's still in the original box, $700ono.
I'm in Sydney, but will ship anywhere if purchaser pays for postage.
Please sms(preferable) or email me your number as I will be in Sydney later this week and I can pick up the dash. Ph. 0419277774 email [email protected]
Thanks,
John
  • 3 weeks later...
Dave: FYI I was enquiring about the problems possibly to be encountered at the RTA NSW with ODOMETER readings being different, also I was asking the OWNER as he/she has the unit and may know this information possibly off hand. As I was a genuinly interested purchaser of this particular unit at the time I feel I was entitled to ask such a question, not only for myself, but other probable buyers.
To be publicly told "dont chat in here" annoyed me because of the above mentioned. As a moderater I think you need to review your tact!
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
