I have an expired AASA licence, but I'll be sending in the renewal papers tomorrow - Would it be a problem if I bring my current expired licence in on the day if they haven't sent out my new one in time?
  • Replies 244
Posted Images
call them if you dont receive it by thursday and they should give you a temp licence/licence number
I've just gotten my car back up and running after a 2year 'rest period' and would really like to participate in this - put me down for a spot and I'll fill out the paperwork this evening when I have my car club membership details handy.
Alright AASA form sent, e-mail sent with all entrance forms and payment made! Can't wait!
Will be good to see ya again Steve.
Yeah looking forward to it Russ, will be good to catch up - Hopefully I can give you a run for your money!
Hope you have a new clutch Steve :D
Haha clutch is going strong Ash! I guess we'll see how strong after Saturday :D Make sure you bring all your 'claimed' kilowatts this time! ;)
Payment just transferred and should be in the account tomorrow - forms will be emailed tonight once I get home and get my CAMS license and car club membership numbers.
Really looking forward to this - I had a blast at the last one I participated in with you guys.
Forms just emailed through!
haha excellent!
Have ~350rwkw at the moment, checked the other day. Had a feeling it was a bit down on power @ Heathcote ;)
Still does mad circle work!
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
