Hey Bec/Leon/anyone, whats the link for the aasa renewal? or should i bring my expired one and have you guys do the paperwork? :P
Just bring teh same form filled out on the day and we will write your license number and renew on top.
Youre meant to do it with them, but I dont think you'll have time now, and with AASA we can work around it. :D
  • Replies 244
Posted Images
Not a problem as long as there are no loose items.
Often some people have a few loose bolts etc lying in the wells - not a good idea should you hit something. A flying bolt would make a fair mess of your egg.
so for those driving up on sat morning, i remember talk of the meet point usually being BP Wallan?
i'm coming from Bayside way so will be jumping on bolte etc and last time i did this we met a group at a servo complex not far into the beginning of the ring rd i believe.
but i guess it depends on where you're coming from
oh and Google says 2hrs, 45mins to shepparton, sound about right?
Timing sounds right.
Just remember there are fixed speed cameras along the way and a fixed speed camera on the main road in shep, make sure you are doing under 50kmh in that zone.
For anyone driving up Saturday morning - just remember you need to be there at 8am.
PLEASE DO NOT be late!!! :D
It should go without saying, but people in the past have made it very hard for us to sign them in and scrutineer their car while we are trying to run events. You are the one that will miss out on runs if you arrive late.
+ 1 glad i came and watched!
296346_10150269466052021_715497020_8014138_5024939_n.jpgAdd a descriptionREADY! SET! GO!!313394_10150269466947021_715497020_8014154_2854953_n.jpgAdd a descriptionREADY! SET! GO!!310093_10150269466997021_715497020_8014155_4120843_n.jpgAdd a descriptionREADY! SET! GO!!300965_10150269467047021_715497020_8014156_5235320_n.jpgAdd a descriptionREADY! SET! GO!!304137_10150269467212021_715497020_8014160_1198688_n.jpgAdd a descriptionREADY! SET! GO!!311606_10150269467467021_715497020_8014169_1465700_n.jpg
Just some of the pics i took!
Had a great day, really enjoyed getting the car out and having a go with a really good bunch of people - thanks to the organisers, sponsors and volunteers who made the day possible, really appreciate your efforts.
I too had a good day, even though I'm not driving again, but may enter next DECA.
Huge thanks to sponsors, committee and volunteers for making this day possible.
And huge thanks to whoever gave me a ride in the pan and wangs.
Gutted, got off a plane Thu night, went to start the car Sat morning and she was dead as a door nail and now wont hold charge. Was looking forward to volunteering and giving Sat night a nudge. So looking forward to the next one already
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
