  • Replies 244
Posted Images
for the GTR owners, is it worth upping the oil weight for a DECA? or will the streeter 10w40 still be ok? i'm thinking because most 'events' are short and sharp, i can prob leave the normal oil in there?
that's if i'm even in.... ooo the suspense :D
Oil isn't the problem.
The only thing you need to ensure is that you dial up 7,000rpm and let the clutch out as violently as possible.
This not only feels awesome, it also looks cool on camera. Once you are moving, add a bit of wheel in and you have 4WD donuts
OOOO YEEEEEEEE
hahahaha love it, :happy:
but seriously this is what you shouldl do :mellow:
I'm sure I have heard this before.....
You've heard it once. That's once in 4 years of decas :)
i just have too much mechanical symptahy to do it :D
Jump in with me. I'll show you mechanical sympathy :)
OOOO YEEEEEEEE
about time you said something smart... :thumbsup:
Tow it up with the STi then give me the keys, I'll make sure it gets driven... Even up that Running/Driving ratio for you :)
You're too kind!
your oil will be fine mate :thumbsup:
Agreed. The runs aren't long anough, and not extended periods of full throttle so I wouldn't worry about it. I'd rather have some temp in my oil after having it sit around between runs.
Planning on letting me show you (and the crowd) a limiter launch or 4WD donuts?
Side point, my diff should be here in a week and a bit.
4WD circle work is on the menu once more~!
Days off work before DECA = no working on car night before DECA = awesome
Remember there is free stuff on offer at this DECA. So if you don't want to compete, get on the officials team and wave flags, pickup cones and watch
a bunch of pure nutters rip it up.
http://www.skylinesaustralia.com/forums/topic/371598-import-monster-sauvic-deca-motorkhana-2011-round-3/page__view__findpost__p__5924332
Guest
    • It's all about reducing the overall output. Reduce the source of it, you have wayyyy less to deal with in every other step and trick you play with. It's why something like a modern vehicle, so VW, Audi etc, there's thousands of tables for the ECU to calculate what it should be doing with the engine.   Why would you NOT reduce emissions the most effective way possible, when it has very minimal tradeoff, AND manufacturers are always struggling to meet the current standards.
    • Ran into this bloke trying to give Oscar some advice pre-race today.
    • Yeah I've personally seen the RB26 pull 30 degrees of ignition timing out of the base timing map if the ECU detects a cold start, it nearly starts misfiring because of it around 2000 rpm and it feels like the engine has no power. I'm just surprised that modern OEM control strategies are actually trading off efficiency for in-cylinder emissions. I would expect something like aggressive EGR dilution + tumble generation valve use to improve EGR tolerance to reduce in-cylinder NOx + HC from crevice volume while also reducing throttling loss vs pulling out some timing if not knock-limited.
    • *** DATE CHANGE *** Date has been changed to Saturday 17th May. The time and location is still the same!
    • You're more than welcome to - looking forward to meeting you!!  The turnout depends on the event and location... Pizza Runs on a clear night can drag out a decent crowd!
