Selling a used APEXi PowerFC, designated for ECR33, comes with hand controller, and instruction booklet.
Price: $1100
I planned to use it with my 25, but that project is taking a different turn.
The current loaded tune (as it was removed from the previous car) Was for an R33 Gts-t, with RB25DET, 256deg Poncams, aftermarket intake and headers, GT3076R, SARD 660cc injectors, blow through AFM, 98 octane pump fuel, and the usual other mods, made about 350-360rwhp @18psi if I recall correctly (if that's relevant).
I bought the PowerFC 2 years ago, and it has been sitting in a ziplock bag on my bookshelf since!). The unit appears to be in very good cosmetic shape, and worked flawlessly in the 33 before it was pulled out.
Location is Sutherland Shire, should a buyer like to pick it up, but I frequently travel to wollongong and camden, so I'm happy to deliver anywhere close to me or in the aforementioned areas. Alternatively I can post the items, though lately my faith in AusPost has dwindled, your choice!
sms me any questions on 0414 889 333, PM me, or post away.
Cheers,
-Todd.
:banana:
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
