I just recently installed a exhaust i imported from the USA. A little more on the expensive but oh my god so worth it.
http://www.motordyne...4205a029f5c97d5
I got the Advanced Resonate Tuning Pipes installed aswell as the Shockwave)) TDX2.
A youtube example of this combo can be found here:
(Black Car, Skip to 1:30) - Not my car btw
The exhaust combo has 0 drone from what i can hear, and when you put your foot down - people will know. Its possibly one of the loudest exhausts i've heard on a street car, and yet so quiet when you want it to be.
Ahhh forgot about the Motordyne. What an awesome sound. Note to OP, there is absolutely no beating the sound and possibly performance (albeit minimal) of a true dual system. The Y pipe single systems just can't compare.
Aftermarket Sedan Exhaust Compilation
Below is a compliation of exhaust setups. Both aftermarket, modded OEM and full custom.
http://g35driver.com/forums/g35-sedan-v35-2003-06/190116-aftermarket-sedan-exhaust-compilation.html
Note to OP, there is absolutely no beating the (possibly) performance (albeit minimal) of a true dual system. The Y pipe single systems just can't compare.
Really?
I'm not sure if its different on the V compared to the Z, but in a NA application the Y pipe systems are better. The scavenging in the low end from combining the two streams gives a noticable gain over a true dual, but the difference in the top end from what I've seen has been in the 2-3rwkW region (which is measurement error).
On the butt dyno I had a mate who went from a Y pipe to a true dual, and he noticed a big drop in tractability with nothing in the top end. He eventually went and had a custom crossover made.
My favourite sound so far has been the HiTech catback on my Z. No rasp, just a nice deep note with an angry edge. Compared to my ultra-raspy current setup (Top Speed Extractors, Berk cats, Buddy Club exhaust) it sounds a lot deeper.
quote me correctly and the context makes more sense:
Notice I refered to the performance as a "possible" gain. The last quote is therefore stating the single systems can't compare for sound as referenced first in the statement. It may have been clearer if I'd put the bracket before "possibly".
So I stand by my post, The dual systems I refered to above to me sound better (deeper) than a single system.
It would be worth noting that the true dual systems from Fast Intentions, Motordyne and Stillen have a crossover section, as Scathing mentioned, which technically does not make them true dual like the HKS, Injen & Invidia. The manufactureres still call then True dual tho
Wiki is in on the act:
http://www.350z-tech...tems_(True_Dual)
Edited by mosoto
I DIY as I have a mate who has a workshop and hoist. If you don't want to DIY, Search for Kermit on these forums. He has a workshop in Welshpool and he specialises in stainless and custom fab.
Fair enough. I thought you were saying that the true duals will give a performance gain, even if it is minimal. In my experience its pretty much guaranteed to give a gain that's better than stock, not as good as a Y-pipe system. Performance-wise a Y-pipe setup is a clear winner.
I haven't heard too many true dual systems aside from the APS, which I thought was quite similar to the Nismo exhaust. But exhaust sound is a very personal choice.
I Highly Recommend you don't get the Headers from USA or any other Left hand drive country. As they made for Left hand drive (steering rack interference), but you are more than welcome to try.
  • 4 months later...
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
