Amazing :D but to be fair, it is an RB28. On gate that is always going to sound incredible.
Fkn lol at the end of the vid :P
alright how about a GTR internalled 2.6L RB25DET
i dont see how people like the 2JZ note..
1JZ i can see
  • Replies 259
what is this faggotry??
1JZ sounds nice.
but 2JZ come on?
Well if you are going to quote non stock engines I raise you this:
When stock though JZs have a higher pitched note just due to the header/head design, if you listen to stock motors side by side you will see what I mean, a stock GTR sounds like ass to me, modded they sound great, but a stock JZ sounds nicer than a stock RB in my mind.
Also this:
Edited by Rolls
i dont like that 2J note at all but i guess you really like the high pitched racing noise.
i like really aggressive shit.
30 and higher is what i want.
this is wicked!
series 3 with full top secret kit and 1200HP
QLD represent aha
Mayb my phone ruins it. Sounds kinda like the gtr at work except more laggy, (gtr at work only has a t88 on it)
Must be heard with proper speakers or headphones.
T88-34D or 38GK?
Im assuming 34D or is there another t88?
yer pretty sure its a t88-34d, makes some huge power figure, the nsw guys might know, its a pearly purpleish colour gtr 33 number plates BUS73D. guys name is sam.
Edited by lilcrash
Not much luck selling it then?
http://www.skylinesaustralia.com/forums/index.php?app=forums&module=post&section=post&do=reply_post&f=8&t=371622&qpid=5948582
Yeah, i guess its the same as antilag.
With the 2 step you use a clutch switch and when the switch is activated the ECU retards timing and adds fuel. The more you retard and add the larger the bang so more boost. The last setup that MAztech did was making 20psi and f**k me the noise was unbelievable. Its not going to be as harsh this time around. We only want about 5-7psi at first to see how it gets off the line :D With any luck the tyres will hold up to 15psi :D
i believe i posted two youtube videos that didnt want to be played as embedded videos
here they are
2.6L RB25DET Onevia Drifter
1200HP Series 3 R33 GTR with full TOP SECRET Bodykit in Brisbane
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
