  • Replies 259
Because they are better...
Maybe to some people but honestly not for me. I am happy with my RB26 and i would have never considered an LS1 when doing my engine swap.
If they were that good Reece McGregor would have ditched trhe RB26 and put a V8 into his GTR but something tells me the mid 7 he runs with his RB is more than adequate :D
I wonder how many seconds you'd get with infinite boost before you did the headgasket or put a hole in a piston.
Any one keen to try it out? : D
With a good tune i think you may be surprised. The exhaust wheel would probably give up before the engine i reckon
Edited by ido09s
How do you tune for infinite boost? On a stock turbo maybe. But on a steel wheeled turbo, all overboosting is going to do is super-heat the intake air and cause detonation.
How does anyone tune a Pro Turbo car when they run 50psi+. Takes a fair bit of knowledge and some skill to do it right the first time, but its done on a daily basis now so its not impossible
There would obviously be limitations to the stock bolt ons, but lets assume they have been changed to cope i am sure the engine would last longer than most would expect.
OK, RB26 vs LS1 is a little different as the RB26 is paired with a pretty good 4WD system. If someone were to figure out how to pair ATTESA with an all alloy V8 only purists would stick with the RB26 :)
Infinite boost is infinite air, so you would simply need infinite fuel :laugh:
thats why i said get a nistune board and a tune, i'm fairly certain the standard injectors and fuel pump could supply enough fuel for 15psi...
my injectors were nearly at peak duty on 0.98bar so i believe im right about 15 on stock killing the engine. let alone stock turbo.
I say stop being a blouse and pick something faster to aim for. A stock LS1 is just a boat anchor and i dont know why anyone would want a Skyline being compared with one.
Why not choose a Veyron, or a Koenigsegg CCXR. Surely this sort of performance would be a lot more appealing :D
I had to laugh at this though..... clearly our laws arent doing enough and obviously do need some reform.... ie school kids should stick to a PS3 and GT5 and most certainly should not be let loose in even a stock Skyline, let alone a modified one.
"I have been on P plates for 3 years now but in less than a month I will graduate to my full license. I know the majority of people on here agree with keeping P platers out of high powered cars is a good idea and I cant say i disagree. But these laws definitley need an overhaul, it is clear that the people who came up with these laws don't know much about cars and as such, shouldn't have been put in charge."
Oh and this is absolute GOLD!!!!!
"The reality of weather you should be in a high powered vehicle or not comes down to your attitude, not your age."
Not that i would think you could be bothered to read through that garbage but it just got worse and worse lol.
Yeh when you set a boost controller to 50psi, that's different than just letting the wastegate free-boost.
And timing? :P Boost does not = air volume.
I dont think the 6.0L v8 is going to get beaten with only $1000 spent on the rb,
theres too much torque and outright nasty grunt , i really think you'd need a gt30 to hose one off convincingly
even if you have enough power , how good are you at launching the thing?? if you dont get a sweet launch then your toast!!
and if the v8 recieves some cams and extractors and tune, then just give up lol, or spent some big money..:whistling:
remember you'll lose your licence if you do 30k's over speed limit which is too easy ...pinch.gif
Edited by SliverS2
I was gonna say, what if your competitors' V8 had any amount of money sunk into it? It's a pretty steep uphill battle!
You're just comparing the engines. You forget they happened to put them into an outright oil-tanker of a car.
As previously mentioned, the R8 is not a bad area to set the bar at. The VX runs what, 13-flat? Easily achievable in a mildly modified Skyline.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
