where from and how much?
looks sick
was looking thru myg37.com
interestingly its a forum member, who designed it himself. Other members loved it so much that
he is now trying to have it mass manufactured. Very talented and hope he gets it off the ground.
Not sure of price. I'll post and see if I get a reply back.
https://www.sau.com.au/forums/topic/371660-v36-body-kit/#findComment-5925646
here is reply re cost-
The bumper is going for $440 CDN and the diffuser $300 CDN. Let me see what the shipping rates are. It may just be that if shipped as a group the rate will be broken down even better. That being said it may have to be that a group buy is set up specifically for you guys.
https://www.sau.com.au/forums/topic/371660-v36-body-kit/#findComment-5926298
Wow that is Sex!
finally something to make the v36 look good.
i want one now. LOL
BOOOOOO, the V36 looks awesome. BOOOOOO i say!
Scarf, keep in mind you have a sedan mate. Might not be a simple fit if you do end up buying this
BTW, dead sexy!!!
https://www.sau.com.au/forums/topic/371660-v36-body-kit/#findComment-5926351
BTW, dead sexy!!!
what worries me about a lot of kits is that they are made from fibre-glass. Had a nice front kit
on my previous wrx, which got completely smashed up just by scrapping gutters and hitting curbs.
Like you said, it wont fit the sedan.
https://www.sau.com.au/forums/topic/371660-v36-body-kit/#findComment-5926621
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
