lil help
GWP021
 Share
hey all i rann a 14.6 on wed YAY!
ok exitment over i got lil probs ive lost constant power to my centre dash
( ie climate control / clock ) any ideas
also how do i do a diags on my comp i found one for the hicas
ill also post this in the maintenance thread but the more people read the more help right? cheers all :wavey:
duno what caused it but when i got my cd player back in it all fired up agin
mabe the constant run thru all those ie: one goes they all go that stupid beep when i open the door is back to ( dam!) cam you get rid of that but keep the one for leavin your lights on? still like ta know how ta do a diags on the comp tho
i found it somewhere but damned if i can remember where
thanks for replyin :)
okly dokly saw the rides parkd out the front this arvo looks great these 2 neat skys side by side in our crappy falcodore town busy as this weekend movin the sister but hell yea definately catch up
  • 4 weeks later...
revivin this post need help agin its time to replace my shocks any ideas on a good place mandurah/ rockingham area wot sort should i go with can i buy shocks that i wont have to change when i drop it an inch or so ( funds are a bit thin for lowerin rite now)
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
