Hey all,
Next happylaps session is confirmed!
Date: Sunday August 21st
Same meetup place at Hypermarket car park, Aspley.
Departure from there will be at 3:30pm SHARP.
On track cruising from 4:30 to 5.00 with an evening meal to follow.
Steak and salad BBQ buffet
Selection of bread rolls
Rump steak
Chipolatas
Sauted Mushrooms
Garlic potato bake
Tossed Salad
Coleslaw
Payment is on the day
Members: $35
Non-Members $40
As per the previous events, If you are going on track as a driver, as a passenger or you're just spectating and joining us for the meal, you must pay the same as everyone else
If you have people coming as passengers then simply say you have a +1 ect, if you have a +1 who would also like to drive on track then please specify as there IS a limit to the number of cars on track :cheers:
  • Replies 112
Important:
Last event we had, alot of people did not turn up and gave no notice.
This causes complications with catering and means other people miss out on the event, this is not acceptable.
As a result, I will not add offenders names to the list to reserve a spot in future
If you are on the list and cannot make it for whatever reason, then TELL US, we need to know
1. Boz+1
2. Boiracer
3. Isola
4. Arebees13
5. Kiwibob
6. Sexy Dave
7. Smity42
8. Smity42's +1
9. olloSKYLINEollo
10. SPR34
11. Sho Pi
12. Sneakey pete
13. Jazzahks
14. TommyR34 +1
15. Mumslayer
16. Grae35 +1
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
