A Couple Problems With My R34 Gtt
Yeah so when you turn key to IGN the fuel pump should run for a few seconds. If you find the fuel pump relay (and have a multimeter, and a second person) to can check the relay inputs. One trigger pin should be either fully earthed The other trigger pin should get 12v from the ECU for say 3 seconds when you turn key to IGN, and at all times that key is at START (note, I said this from memory, it may be the other way around, ie one pin always has IGN 12v and the earth has continuity to earth when you turn the key) One Pin should have a good battery voltage The last pin goes to the fuel pump + Also note that if the power to the relay is good, and the relay is working, it is worth checking the pump has a good earth too. There is a computer in the standard system that increases the earth resistance to slow down the pump when not required, pretty old school and it may have failed
All this talk about fuel and fancy ECUs, meanwhile my poor old R32 has neither.... When the ignition is turned on, should there be power running o the fuel pump constantly or just for the few seconds it usually takes to prime the pump? About to go have another look at it, have watched some YouTube vids on how to use a multimeter and looked at some wiring diagrams but really have NFI what I'm looking for because electricity is invisible
Yuh....but weren't all the supertourers, except maybe the Audis, FWD? I don't recall any of the others being AWD.
They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox) They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox)
By funkymonkey · Posted
Inspiration: https://www.nissan-global.com/EN/HERITAGE_COLLECTION/Primera_GT.html
