Nick, give Mark at SA Motorsport Tyres a call on 0409 288 380.
He's the SA Federal and Hankook motorsport dealer, he'll be able to advise you of something decent for daily use. I'm waiting on him to sort my wheels out before we go tyres, but he did have some ideas and will be able to tell you whether it is or isn't over the top (and he'll be honest about it!).
Tell him Ryan from Pure Motorsport sent you :thumbsup:
https://www.sau.com.au/forums/topic/371726-tyres/#findComment-5927006
Cheers,
Will do. Whereabouts is his shop located? Would he be able to fit tomorrow morning? Not too keen to keep the space saver any longer then it needs to be!
https://www.sau.com.au/forums/topic/371726-tyres/#findComment-5927026
the 595ss's can be had in that size for about $125 + fitting (from option1garage)
Anyne know whereabouts in Adelaide i can drive in and drive out with a couple of these tomorrow morning? I called Mark and left a message, hope he calls back.
https://www.sau.com.au/forums/topic/371726-tyres/#findComment-5927165
hey mate
contis are a very well engineered tyre, OE fitment for alot of vehicles
pirellis are abit soft in the sidewall, more of a family highway tyre
federal ss-595's are a good performing tyre but very VERY noisey
bridgestone RE001's as suggested by kiwi are a good performance tyre with very low road noise, very stiff in the sidewall for handling
https://www.sau.com.au/forums/topic/371726-tyres/#findComment-5927304
Rear tyre just got shredded (mrs driving). Booked in at NTT (North Tce Tyres) tmrw morning to get a couple of either Pirelli P7's or Continantal Contact 3's (235/45/R17) for $198 each. Thoughts/recommendations?
my thoughts....these days you can get as good or better tyres from the less known brands much cheaper.
Personally I run the 595SS Federals (and haven't found them noisey), I'd also look at falken fk452. Or generally, the top tyre in the range from any of the cheaper brands, they are a very good price/performance compromise because they can't change the top brand premium.
https://www.sau.com.au/forums/topic/371726-tyres/#findComment-5927945
How much? They're a bit hardcore for everyday use aren't they?
Because I drive a lot in the mountains here I need something decent.
Up here "Option 1" are very well priced.Check their web site for prices and compare with local dealers.
https://www.sau.com.au/forums/topic/371726-tyres/#findComment-5928057
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
    • I'm shocked, you've owned a Skyline since 2006 and never joined SAU before now! 😮   Welcome, it's much quieter these days than it was in 2006, but lots of very knowledgeable ones lurk around here. I actually think in outage we've forgotten more about Skylines than anyone knows about them today... 😛
    • So it could give us some info. Such as we find out what number they started at, and we know how many of those blocks came before it.
