Sooo, I've done several Group Buys for Sway Bars now, and they've all gone very well, but I haven't really catered for you guys :blush:
Are any of you C34 drivers after Sway Bars or Whiteline alignment parts?
Feel free to post in this thread or send me a PM; I'm happy to help.
Cheers, Dale.
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/
Cheers, Dale.
The 25G is RWD and has no rear bar. What do you suggest?
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5927445
I'm not really clued up as to the differences in the subframes among the different models, so I'll have to defer to the more experienced guys on that. I'm going to have to pay more attention.:blush:
If we can ascertain what subframe it is; I'm sure we can find a bar to suit.:thumbsup:
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5927479
Cheers, Dale.
i could be interested pending prices
my mate bought a 33 that was originally a gts (non turbo but converted in japland with turbo everything except rear way bar) all the mounting points were there under the car and on the lower suspension arms so we bolted a whiteline bar in there
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5927773
Check out the Cusco ones while you're at it - may or may not be more expensive.
Had a quick look at their website - bars are about AU$350 but they don't seem to list Stagea ones so onoly the Sklyline ones known to fit would be of interest. Probably Aussie made ones would be a better bet.
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5927932
Had a quick look at their website - bars are about AU$350 but they don't seem to list Stagea ones so only the Skyline ones known to fit would be of interest. Probably Aussie made ones would be a better bet.
$350? I'll be able to smoke that pricethumbsup.gif Should be around $230-$240ish.
^^ agreed.
can also use R33 GTR swaybar on front
Thanks for the tip; I'll get some prices together.
Cheers, Dale.
Edited by Daleo
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5927992
Ok, prices;
Front AWD;
BNF27Z; 22mm ADJ AWD RRP; $265 Me; $220
Front 2WD ONLY!
BNF24Z; 24mm ADJ 2WD; RRP; $265 Me; $220
BNF24X; 27mm Fixed 2WD; RRP; $265 Me; $220
Rear; 2WD & AWD;
BNR11Z; 20mm ADJ; RRP;$299 Me; $240
BNR11XZ; 22mm ADJ; RRP; $299 Me; $240
BNR11XXZ; 24mm ADJ; RRP; $299 Me; $240
Links;
KLC108; Front Heavy Duty Ball Link; RRP; $180 Me; $120
KLC109; Rear Heavy Duty Ball Link; RRP; $180 Me; $120
Let me know what you think.
Cheers, Dale.
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5928081
I'd be keen for front and rear AWD swaybars, anyone got recommendations for which thickness to go for on the rear one?
I would tend toward the 24mm due to the extra weight in the rear (a lot of glass & steel high up in the body) and this will also tend to reduce understeer.
I'm not really familiar with the handling bias of the C34 but I would imagine it is understeer biased.
Feel free to correct me.
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5928107
Good prices!
Sway bars are the best bang for buck investment in handling. Worthwhile for a stock or modified Stagea. Improves cornering no end and there in NO DOWNSIDE - no harsh ride or other problems.
I have the 24mm solid rear which is a big upgrade on the stock but would not suggest a smaller one.
For the front the SK kit had 24mm made to special order but the 22mm should be ok as there is a tendency to understeer.
NB I painted mine black as even though they are an upgrade with no implications for reduced safety (the opposite in fact) they are considered a "modification" that might incur unwanted attention.
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5928266
Good prices!
Cheers mate; I aim to please!
Best description of the benefit of fitting Sway Bars :thumbsup:
Mine are also powdercoated Black; stealth FTW!
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5928452
Does powdercoating void warranty? I've been enquiring about powdercoating rims and one dude said that it would compromise its structural integrity..
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5928466
i'm pretty sure powder coating ovens wouldn't get anywhere near hot enough to affect the heat treatment of the metal used.
https://www.sau.com.au/forums/topic/371762-c34-sway-bars/#findComment-5928471
    • My purchase experience was no where near as glorious as yours but still a significant moment in my life! Yeah that's a bit of a dilemma as to whether you bring it back or not!  Obviously a massive waste of time and effort to bring it back if you're only going to move there anyway!
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
