Either of these
East Coast Customs (Workshop)
2/14 Boothby Street, Kedron, QLD
Contact Rob on (07) 3359 5466
info [at] eccustoms.com
http://www.eccustoms.com
EFI Performance (Workshop)
Unit 3/15 Emeri St Stapylton 4207
Contact Rick on (07) 3801 80 75
rick.w [at] efiperformance.com.au
http://www.efiperformance.com.au
I got my nistune done at EFI about a year ago, Car still hauls ass and has had no issues shaun is like the car wisperer every car i've seen come out of there is a monster compared to when it went in.
I got mine done for mid $900... $960 maybe? Male it a round $1000 to be safe. That was fitted and tuned. Runs like a dream, smoother all round and slightly more fuel efficient as well :)
The Nistune solution has several advantages over other systems as it maintains several factory options such as cold starts, R+R if something goes wrong etc that the aftermarket ECU's can't compete with. Nissan spent millions developing and tuning their cars, no 3rd party will ever get the basic stuff as right as they did. that's part of te reason why I went with it.
Thanks for the responses guys so what did they charge u random hero?
About 1000 fitted and tuned?
It's either that or I go and safc 2 I can get one of them preety cheep
They had a deal going for $1000 (I think they are still doing it)
Safc is a really bad choice it's only a piggy back system and in my experience thats just throwing the money in a hole.
Boz has the right of it the stock ecu as a standard unit is quite the clever bit of tech, combining it with a nistune to make it a tuneable ecu with the standard safeguards in place you'd be mad not to utilise it.
Edited by RandomHero83
    • Dang I looked at this for so long until I realised it was for the inner rod. I was so confused. This looks like a great tool. Another injected plastic box for my collection. I for one am a torquer. I'm far too anxious and neurotic to not use the correct torques whenever I can. I do honestly feel like my wheels will fall off if I dont.
    • Not sure if you're being serious? I, and all the car people i know, ALWAYS use a torque wrench for wheel nuts. I assumed any car person, apart from tyre centre monkeys with rattle gun in hand, would do it properly.  Anyway, no further reply from me on this unless legit discussion from OP or his query so, over to you, knock yerself out.
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
