  • Replies 40
The RE001's were 'better' than the 595SS in my opinion. BUT, keep in mind the rather large price difference. For what the 595SS's are, I would get them again. I don't think the 595SS is really that far behind the RE001's, maybe you should consider the 595EVO (which is one between SS and RSR) or even the RSR's. I think if you get the SS expecting them to be the same or better than the RE001 you will be dissapointed, but if you get the SS looking at the price gap between the SS and the RE001, you will be pleased. If that makes sense. haha.
I wouldn't buy locally if you want a good tyres at a reasonable price .buy ad08s or dunlop speed stars for street tyres with grip. You can't expect a cheap tyre with performance to last ages. I run ku36 up front and federal RSR down back. Perfect combo for street Tyres that are good on track. If I wanted great on track, then obviously another set of wheels and semis would be ideal
I think unless you are competing (phillcom rally, etc) or have a large disposable income, dont bother with an amazing rim/tyre combo. Go a RE001, 595SS or KU36 and work on other small adjustments that will see your times drop.
but whats the point of spending $2000 on a set of real semis to cut a few seconds on the 3 practise days you attend a year?
no point in spending the coin for a few trackdays. there are plenty thougout the year, Ill be at the August 19th day
sorry J-rad, not everyone runs BCT's by choice
Maybe because my cars a daily driver, so cutting tenths of my drive to work isn't really that important to me.
But in the few weeks I drove around on Adrians CSTs with 595s I was impressed with them, never really tramlined or anything. Well worth it compared to KU36 etc
there is absolutely no way I would put top shelf tyres on a daily driven car. As it turns out, my 32 is daily driven, and the 595SS gives me a nice daily drive, but you can poke a bit of fun at them as well and they are fine. For $140 a corner, I simply cannot complain. Keep in mind that is $140 fitted and balanced, its all well and good to buy tyres from interstate for XXX price, but youve got shipping, then fitting and balancing. I'd rather give my money to a local business who is offering a good deal anyway.
Keeping in mind that your tyres are the only part of your car that touch the ground Damo :P
i'm probably going to either try some KU36's or 595 RSR's next time i need tyres.
for me, my car doesnt see much driving, but when it does i want it to grip well. last thing i want is something that will just spin if i put the foot down. for some reason spinning wheels doesnt get me hard like it does other people.
if i drove daily and needed the tyres to last, then i'd go for something harder compound and maybe not as much grip.
now i got a house and the missus can see the bank account, i've gotta spend wisely on the GTR
i'm probably leaning to the RSR's because for the price from option 1 garage, i can rotate them better since my car does get a bit of camber wear on the inside. and i think KU36's wont last and i'll have one side bald with heaps of tread on the outer side
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
