I believe the ecu itself has been flashed which is why I can have the safc on zero and still not ping.
Granted I'm only using the factory sensor but im not hearing or registering any knock on the safc either. The car ha knocked before with too much boost.
Sounds like it might be worth at least checking timing and making sure it wasnt advanced when it was tuned.
I might check the manual and see if there's anything I can check with the multimeter for the fuel pump.
I'm reluctant to take I to a local place as they have a tendency to charge for hours and hours and come back with nothing.
  • Replies 51
In that case find someone with a wideband gauge and at least use that yourself, better than nothing. You really shouldn't be tuning fuel without one!
Knock ears would be great as well but you aren't exactly going to go spend $1k on them for a back yard tune, maybe a visit to Melb is in order? Be cheaper than a replacement motor that is for sure!
Ok one more update.
I went for another drive, safc on zero, but this time I disconnected the exhaust gas sensor/O2 sensor. This is another test in the sevice manual for missing.
No missing at all with plug gaps on .8
I considered that because it is a cold night it was masking it so I sat in an industrial estate with my lights off and held 2500 rpm for period until water and oil temps were nice and warm and the bay was nice and soaked. It occasionally missed/popped during this high idle period but did not miss while driving or under load.
I'll test again during the day when it's warmer and might grab the sensor from my mates car.
The missing if caused by too rich will generally be worse in cold weather as more air, but heat makes the coils spark worse also.
Really think everything will be solved with a trip to a competent SAFC tuner who has tuned skylines before.
O2 feedback is only below ~3.5k on low load, if its missing above this it can't make any difference.
Also O2 feedback generally makes it leaner, if anything it should make the problem worse unplugging it.
Edited by Rolls
Interesting. Just to clarify, we're talking a ca18 here not an rb. I only mention this as you referred to skylines before.
See how it goes when the temp is higher. Cold dense air might have been masking it. Previously the critical miss point was 31-3200rpm
Update: Drove the car to work today as it's a nice sunny day, it's supposed to be 20 here today too so the drive home will be another good test. No missing at all with the Oxygen sensor disconnected.
Considering it's primarily track only I'm not in a hurry to replace the sensor. I'm going to put it on a dyno this weekend and check the AFRs after all my stuffing around and make sure it's safe before it hits the track again.
At the same time I could use the low throttle point map in the SAFC to take a bit of fuel out of at the cruising RPM with low throttle. Not as good as relying on the Oxygen sensor but better than nothing, that will only be if time permits as I'm not really concerned about highway economy. Let me know if I'm missing something else by not replacing it though.
So long as it drives well on WOT I'll be happy.
Side bar: Do the CA's have a diagnostic type port? I know they don't have a CONSULT port but do they have the standard 9 pin diag port? If so I can hook up a little diag box and check my timing easily too.
Dyno was a fizzle, the guy was a muppet. Went as he could fit me in this Sat, my n0rmal dyno guy was busy.
After dicking around for ages and continuing to tell me it was lean all the time, I added full correction for fuel on the SAFC (50%) the car is missing, popping flames, big plumes of black smoke from the unburnt fuel and he goes still lean. turns out his sensor is f**ked.
Not only that but he wants to run it by sitting at 60km/h in 3rd, no load no boost, then continuing to add load on the dyno and adding throttle so it just holds at 60km/h so essentially we're driving up the steepest hill in the world at 60km/h in third. The car just loves that.
He spent more time talking about his divorce, pending lawsuit with the epa, and on the phone to the guy from Mainline trying to work out how to give me the damn graph i needed to see (he could only give me real time data and nothing recorded over a run) than he did anything else.
In the end, he cracked it, I cracked it and we went our separate ways (I didn't pay anything). I'll go to my normal dyno guy next Saturday.
Good news is that other than when it had stupid fuel in it, it didn't miss on the drive over or back or on the dyno. Must have been the O2.
Sorry if this has been posted already. Whats your fuel pressure?
Not having a dig at all, but these sorts of threads pop up fairly often and there's never any basic diagnosis done. Just alot of parts thrown at the car in the hope something will fix it.
Hope you get it all fixed soon :)
  • 3 weeks later...
An update to this.
I've since bought and fitted and AEM wideband so now I can just road tune the car myself, unsurprisingly it's a little rich down low and by a little, i mean a heap - richer than 10:1 - and
then it's a touch lean up top nipping at 13:1 so I'll bring that back to around 12.5 and dial out some fuel down low.
Should be apples :)
EDIT: Forgot I'd already been a good boy and updated about the O2, woops.
Edited by ActionDan
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
