Cleaning the cold start regulator will do nothing as it is only a valve that opens and shuts. The disc is half open at 20 degrees celsius making the idle about 1400RPM, so when you start your car and its starts that second time if it idles high when cold and low when hot then the regulator is operating fine.
As for power FC, it could be running a tune that is able to handle a rich cold start and yes you cold have had a faulty ECU but i don't know why or how the ECU would be fine the 2nd start and reset hours after only when its cold. Then in summer this problem does not occur (well for me), that's how i figured out it was a leaky injector then i pulled the rail out and primed the pump and saw it drip. 08r3308 you should do this because your going to have to eliminate possibilities with so may different opinions.
I'm starting to get a VERY rich fuel smell which happens only for about 2 seconds when I start the car. Not when I prime, only start. Ive got brand new injectors seated in a fuel rail with all brand new seals and rings. There is no smell of fuel in the engine bay at all. I can smell it in the cabin for a couple of seconds. Fuel hoses are all tight and secure. I think I'm just running way too rich and some raw, unburnt fuel is making its way into the exhaust before being burnt. The power FC isn't giving me any starting issues.
I too can now suggest you check your injectors. Its not hard to do. Have someone keep priming your fuel pump and just have a smell around the engine pay. Its a PITA to yank out the fuel rail, and the smell of fuel is really strong so if it is leaky I'm sure you will smell it.
Your engine bay should NOT smell like fuel.
When you go to fill up with petrol do you get that "PSSHH" sound when taking the cap off, also on hard right turns you will get a stronger than usual fuel smell ....... if so then its the fuel filler cap. Other than that there is a million and one things to try.
Do you really think if there was a leak that you won't be able to smell it? Fuel has one of the strongest smells and even a drop in your engine bay will be very distinct. Ive got my old fuel rail here which was pulled out of the car to fit in the new rail. Ive pulled out all the injectors and the rubber is still nice and supple and there are no cracks or tears.
I just think that if there was leaky fuel, you would smell it. Just loosen the rail where it sits, lift it up and them keep priming your fuel pump over and over and watch for leaks.
Yeah I was thinking about that... if its leaking it will be leaking into the piston causing the cylinder to flood and bog down. Why not let it die down as it does then rip out the spark plugs and look for wetness. Its MUCH easier to pull spark plugs than it is to pull the rail.
My old car did and that. I just tried it out on this car(and I recall when I used to go fill up) it does not do the psssh sound. I don't think it ever has... I took the cap off my other skyline and chucked it onto this one. The car is warm so I'm gonna let it pressurize then remove it see if it makes a difference. Is the filler cap not going pssh a problem WITH the filler cap?
Edited by SargeRX8
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
