  • Replies 51
Retrofitting a dual clutch autowunderbox would have to be a fairly significant challenge. I'd go out on a limb and suggest that it would be nigh on impossible to achieve it without considering a complete R35underR32 transplant to get all the systems present and accounted for. Budget - very very large.
So, assuming that you want something better than an H pattern box but can't really afford to spend the $100k or so to put the R35 stuff in, then the most realistic option is that you'd be looking at a Hollinger sequential. And really, it's unlikely you could afford that either.
Edited by GTSBoy
I have just spent close to 7k on labour and Osgiken 5 speed box, noisy but very tough im not looking to change it anytime soon but its just a question, how can you possibly match the speed on the gear changes that the r35 can do, as thats the main advantage of that car
Edited by GTRAAH
Well, that's the reason I was saying that it would be a massive exercise verging on the impossible. That whole interaction between the gearbox and engine needs to be replicated, and so you'd need to come up with an engine management solution for the RB that would do what is needed, and have all that fine tuning and development work done that has probably cost Nissan tens of millions of dollars to get right (as of the 2011 R35 release). Tough ask.
of course not but im saying a 650hp rb26dett will be much much driveable with that transmission and alot quicker
A 650hp 26 will never be nicely driveable :P
You've got lag to content with, the R35 simply doesn't.
Gearing is also another factor you'd need to think about. A 35 box is designed around its weight, torque/power range and gearing...
A 2.6ltr will be very different.
Realistically if you want lightning fast shifts you need a hollinger, or a manualised auto or something.
-5 arent that laggy. I feel its easily driveable and i have close to 500hp yeh i know 650hp are probably close to those turbos limits. So what can you do to put a manualised auto? has anyone ever done it? and what makes a hollinger quick shift? My future plan is to convert it to a RB30DETT with the -5's i heard tha its a very nice mix. Another question now im getting off the topic sorry lol But once you convert it to a rb30dett can you bore it out to 31 or 32 getting closer to the 3.8lt r35 :) Plus its much lighter so that should make up for the extra few hundred cc's
Edited by GTRAAH
lol no i just like response. You'll never get a 2.6l/650hp, responsive.
You'd need to get a massive stroker for that.
What would you say if my T78 RB26 was on full boost (24psi) by about 4000rpm and makes 460rwkw on 98. The car runs 135mph so its making decent power. Thats about 500rpm more than a stock RB26.... or is your idea of response full boost at 3000rpm
Isn't the 35 box at the rear of the car (for better weight distribution) like a transaxle? As far as I can tell everything on the 35 is built for the 35 alone. Oh the headaches.....
Re response- 2.6 RB with low mount twins, 400rwkw on 18psi, on pump fuel, full boost by 4000rpm with enough meaningful boost between 3000-4000 (10psi from 3000rpm) to make a substantial difference, has more power here (3-4000rpm) than stock and therefore actually feels more responsive than stock. (and yes I drove it and a stocker back to back to check). Also runs Motec which made big difference. Everyone's got a preference so...........
Buy an R35?
Im keeping my 94" GTR32 for life! It will be my hobby to experiment. Not worth selling... slowy slowy it will fully customised to my perfection interior exterior and engine. One day i might buy the r35 but till then my gtr 32 is my baby. I just cant get enough of the feel of it. maybe in 20 years when i open he garage and its in 100% condition body will still be 97% Original but the interior will be highly futurised. It might open some eyes when i drive it out on sunday cruises lol. It is not my daily driver and will never be.
If you want to get closer to the 3.8L mark, just move to an FG XR6 motor.
No i aint letting go on of the RB if anything i will build on top of it till it cant take no more then build around it to keep it healthy then garage it and take it out on special outings and cruises. Never selling it!!! i dont look at the car as money its my hobby. I will never be at the point where ill say i need money i need to sell it. Its not money to me.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
