drop ricardo or x-trac a line, im sure they have something that can be used for onehundred thousand....
RICARDO TRANSMISSION
x-trac
does anyone know anything thats as fast as a dog box but isnt? Is there a way to convert a trasmission to semi auto?
  • Replies 51
Im keeping my 94" GTR32 for life! It will be my hobby to experiment. Not worth selling... slowy slowy it will fully customised to my perfection interior exterior and engine. One day i might buy the r35 but till then my gtr 32 is my baby. I just cant get enough of the feel of it. maybe in 20 years when i open he garage and its in 100% condition body will still be 97% Original but the interior will be highly futurised. It might open some eyes when i drive it out on sunday cruises lol. It is not my daily driver and will never be.
import one of those awd v37 skylines with the dsg box as a track car. strip parts and retro fit
Whats a dsg box? You recon the dsg box wouldnt be hard to put on the GTR? And why couldnt u get a similar style dsg box on its own?
You'd be hard pressed to pass on a hewland transaxle but get 25k together before even enquiring. Then another 10k to install it into a GTR and get the suspension right.
Seqential 6 speed, transaxle layout.
When you find the rest of the specs that they didn't tell you about in the video, post up, cause there is more too that car than you'll realise. Things like carbon prop shaft come to mind for one thing. Also diff ratios IIRC were altered as well :thumbsup:
Considering nothing really happens until after 4500rpm, that is not responsive.
Also doesn't show you how much delay there is inbetween gears (like pedal/foot shots). He could have his for flat to the floor for 1 sec before anything happens and you'd never know it.
Carry on.
Carry on.
So stay above 4500rpm which he manages to do pretty easy :whistling:
I believe R31nismoid is referring to response on the street, whereas on the track, any turbo/stroker is ok as you are staying above 4k rpm all the time
The mine's 34 is not as simple as it looks, it could be running 100 octane fuel for all you know and the engine may need rebuilding after each race?, things that you dont see in the video
Just wait for Ikeya to release their paddle shifter :)
-5 arent that laggy. I feel its easily driveable and i have close to 500hp yeh i know 650hp are probably close to those turbos limits. So what can you do to put a manualised auto? has anyone ever done it? and what makes a hollinger quick shift? My future plan is to convert it to a RB30DETT with the -5's i heard tha its a very nice mix. Another question now im getting off the topic sorry lol But once you convert it to a rb30dett can you bore it out to 31 or 32 getting closer to the 3.8lt r35 :) Plus its much lighter so that should make up for the extra few hundred cc's
I don't know where your info comes from but what makes you think an RB engine is lighter than a VR38? that's completely wrong.
also there are bigger differences than just capacity. one is a I6 one is V6 for starters which really alters the engines characteristics. the Vr38 also has VVT which helps too.
the ONLY viable option for you is hollinger. its $20K which is cheap for the advantages it will give you. with the strain gauge in the gearknob and flat shift (ign cut) mapping in your ECU you can do clutchless full throttle shifts. still not as fast as a DSG (like the R35) which it has the next gear pre-selected and is just opening one clutch and closing the other.
so forget all the crazy ideas and just buy the hollinger. it fits easily and will transform the car. you will have change from $30K even buying the box/clutch/tailshaft and installation.
There are alot of could of which could be said but they said the engine is not bored and its a mines stage 2 engine. I don't think mines have released a stroker kit(don't count me on this, but I heard of any...). They are also using HKS2530 twin turbos which are super responsive on that car. Just the way they spoke of it, and the subtitles, and what it was built for will lead you to believe that it is a super responsive R34GTR. The way it goes from 4krpm to 8krpm in less than a second.. thats response to me.
Sure there could be more shit under there we can't see but the generals are outlined. The 26 coupled with those turbos alone will be a fairly responsive setup. It is a 600hp car. I wouldn't imagine its a non responsive car lol. And you can tell when they touch the throttle, Ive driven the R32 VW golf with DSG gearbox and when you plant your foot there is like a second of nothing while the car gets it self into gear. In a manual, pretty much as soon as you let go of the clutch and back on the petrol the revs will climb almost immediately. Ive got a hypergear turbo and there is nearly no delay at all at 3500+rpm and the foot planted from a down shift.
If you swapped R34 diff gearing to GTS4/GTR gearing, you'd get the same result... Given thats what Mines had done. You are talking 3.4 --> 4.1-4.3 diff gearing. Thats such a massive change it's not funny.
Also combined with super light flywheel, carbon prop shafts and some wheel spin, course it'll spin up fast.
If you put the normal diff gears back in... it'd be no more spectacular than any other R34 GTR build of that power level.
You've never had a GTR with 600-700hp worth of turbo on it, I can tell you now there is noticeable delay between full open throttle and coming onto boost when you plant the foot.
Either way the Hollinger really is the only viable option.
Wait where did i say that the RB is lighter then VR i didnt say that
PS
Not sure if im right or wrong but i perosnally beleive that the RB26DETT has more hidden power then the VR the VR has basically been modded more then the RB from the production line. AAnd yes dont get me wrong the VR has ALOT of potential aswell. but because of the law changes i think the VR came out basically almost with stage 2 mods from the factory line. The Z-tune is how the rb26 should of rolled out of the production line in the fisrt place.0-100 in 3.5secs and ive read articalls that it does the quarter in the 10sec mark.. And that is a healthy tune and can be driven as a daily
Edited by GTRAAH
Wait where did i say that the RB is lighter then VR?
-5 arent that laggy. I feel its easily driveable and i have close to 500hp yeh i know 650hp are probably close to those turbos limits. So what can you do to put a manualised auto? has anyone ever done it? and what makes a hollinger quick shift? My future plan is to convert it to a RB30DETT with the -5's i heard tha its a very nice mix. Another question now im getting off the topic sorry lol But once you convert it to a rb30dett can you bore it out to 31 or 32 getting closer to the 3.8lt r35 :)Plus its much lighter so that should make up for the extra few hundred cc's
Word on the street: spool will sell a fully prepared 3.4L bottom end for 9k.
PS
And you base this on entirely nothing.
Prepare to get slammed.
You are very wrong.
1. The Z-tune is not a 2.6ltr
2. The VR has to deal with emission laws that are what, 10 years newer/stricter in every single way.
3. RB26 is a motor essentially from 1987/88
4. The R35 is higher production, factory, with a warranty etc. Z-Tune was basically just a once-off special model not to be made in high production therefore giving to some lenience in many cases.
Who cars about 0-100 and a 10 sec 1/4 mile. The R35 isn't just a straight line car. It is an overall package which i said in the 3rd reply.
If a VR came with "stage 2" mods (whatever that means), when why with nothing more than a tune/boost are people making an extra 40awke more? It's because of emission & longevity rules. Same as a RB26 you get similar gains with tune/boost.
You are very wrong.
I forgot to mention the 2.8L stroker. That also should of been standard and not the 2.6.
And the Idea of the Rb26 was probably was being worked in 87-88 but was refined and produced to GTR spec in 89.. What i mean by stage 2 is yes the ecu was tuned more then the average tune. Yes the Rb26 can be tuned slightly and make more gains and it could also be tuned again to make more gains. Dont know what the limit is before you need extra parts. What im saying is the VR was probably tuned more then the Rb26 straight off the line. who knows. And yes it can be further tuned to make more gains aswell. Anyways Who knows what they did in the factory and what tune they did and comparing the ratio to the Rb26 what was tuned more i dont know. Im just guessing because the laws were different before.
Why is it that the 180km cluster was inplemented into the Older GTR cars and not the newer ones? Did the law of speed change over the eyars which allowed them go harder with the factory tune?
Edited by GTRAAH
I meant the Car is much lighter not the engine.
Spool does it for 9k, I wonder how those strokers will go with the -5 and how responsive they will be. And the petrol usage difference..
Have you got a website i can check this out? Is it advertised?
Edited by GTRAAH
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
