I forgot to mention the 2.8L stroker. That also should of been standard and not the 2.6.
And the Idea of the Rb26 was probably was being worked in 87-88 but was refined and produced to GTR spec in 89.. What i mean by stage 2 is yes the ecu was tuned more then the average tune. Yes the Rb26 can be tuned slightly and make more gains and it could also be tuned again to make more gains. Dont know what the limit is before you need extra parts. What im saying is the VR was probably tuned more then the Rb26 straight off the line. who knows. And yes it can be further tuned to make more gains aswell.
Why is it that the 180km cluster was inplemented into the Older GTR cars and not the newer ones? Did the law of speed change over the eyars which allowed them go harder with the factory tune?
dude, every car sold in japan has a 180km/h speed LIMIT and as such a 180km/h maximum on their speedo. that includes the R35 GTR too...
I'm trying to help but getting close to giving up. all this stuff about the R35 being tuned hard and thus doesn't have as much potential is just nuts.
for starters look at the facts.
RB26 produces 280hp from the factory (as per the japanese manufactures agreement of the day)
VR38 produces nearly 500hp from the factory.
2.6 vs 3.8L
I6 vs V6
wet sump (and fragile at that) vs semi-dry sump
5 speed synchro box vs rear mounted 6 speed DSG transaxle
no VCT vs VCT
there are so many more but the fact is the VR38 has plenty of potential. have a look at how many VR38s can easily produce 800hp then see how hard it is to get a GENUINE 800hp out of an RB26. it's not easy.
  • Replies 51
2.6 vs 3.8L
I6 vs V6
no VCT vs VCT
I understand the VR has much more adjustments and ALot of potential, Just saying from the weight ratio point of view, and the ammount of tuning they did at the end of the production line. Dont worry about it im just curious about things LOL
And the Idea of the Rb26 was probably was being worked in 87-88 but was refined and produced to GTR spec in 89.. What i mean by stage 2 is yes the ecu was tuned more then the average tune. Yes the Rb26 can be tuned slightly and make more gains and it could also be tuned again to make more gains. Dont know what the limit is before you need extra parts. What im saying is the VR was probably tuned more then the Rb26 straight off the line. who knows. And yes it can be further tuned to make more gains aswell. Anyways Who knows what they did in the factory and what tune they did and comparing the ratio to the Rb26 what was tuned more i dont know. Im just guessing because the laws were different before.
they made their new race engine 2.6L to compete in a certain cc class because the 2.4l(iirc) just wasn't making what they wanted in the cc class it would have been in.
Oh and everything else you said in that post was gibberish.
How long have you been into skylines?
I meant the Car is much lighter not the engine.
Spool does it for 9k, I wonder how those strokers will go with the -5 and how responsive they will be. And the petrol usage difference..
Have you got a website i can check this out? Is it advertised?
well when people say spool rb34, have a big guess at what you might type into Google to find such a product??
R35 is just better in all ways.
But ill take an old modified datsun chassis running an RB any day of the week over a VR R35
Edited by 045HOW
@045how
I had a guess and it was such an amazing guess i actually typed spool rb34. And have a guess what came up the spool website and have another guess what i found in that website F**k all about rb34dett stroker engine for 9k. Mad guessing ay . your turn to do some guessing guess what that link is for the 9k engine and paste in here :/
@045how
when i say word on the street, i mean word on the street.
in as my mate contacted them and was given a quote for a bottom end.
if you are that interested, how about you simply contact them and enquire for yourself!
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
