Hey guys these are all the left over parts from my skyline after doing my last topic and not getting much interest in selling the whole car as it was not complied i decided to gas axe it and part out the rest im not asking for much for the little bits and pieces but fair prices will be on the good items and i will also give some things away if people wanna come and pick it up. i also can delivery to brisbane so just ask. If i dont get much interest it will go to the tip just like the body did!! Prefer the bigger stuff to be up i dont mind posting smaller stuff. PM me any questions just not stupid ones!!! Any parts I've missed i will fix up and add the prices!!
Nismo indicators $50
Front bar lights $20
Doors $150 ea
Dash $50
Ecu $100
cluster $100
Bonnet $100
Boot $100
side windows $50ea
Rear window $100
carpet $50
Tein Ha $800
Rear lights $80
ECU Harness $100
Steering column $150 has boss kit
Coolant bottle $10
Door trims $50 the lot
Rear hicas $50
Rear 2 way diff $800
Steer rack and sub frame $150
Z32 air flow meters and trust filters $400
gtr air flow meters $100
Rb20 air flow meter $20
gtr alloy intake with filters $100 foam needs to be replaced
Trust cooler $500 Has a dint in tube but its fine check pic
Bovs $20 ea
Fuel pump$10
Catch can $5
De cat pipe S/S $30 i think i have 5
K&N panel filter was removed from a 4 door skyline may be the same as 2 door $10
HKS manifold $1000 Firm T25 flange New unused
50mm HKS Wastegate $800 Firm New unused
Full body harness $200
RB25DET short block cp forged pistons, eagle rods, arp main stud kit, jun coller, king bearings $3000
RB25DET Head has been ported 3 angle valve job new stem seals and i have a 1.2 mm cometic head gasket $800 for head and gasket.
Edited by Gus.
https://www.sau.com.au/forums/topic/371871-skyline-gtst-parts/
Hey mate, I'm after that shelf thin that covers all the wiring under the steering wheel. The place that people usually mount their turbo timers etc. My clips have broken so need a new one for a R33.
Please PM me your asking price inclusive of postage. Thanks.
Hi Gus,
Do you know what spring rate the Tein HA's are front and rear?
Are there any knocks or leaks with them?
How are they for daily driving?
They are 7kg front and rear they both say 1070
no leaks
yeah they ride good
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
