Can someone help me, I have an RB20det from an R32 GTS-t, I installed a nistune board in the ECU and had it tuned and it was running fine. Since then I have replaced the afm with a Z32, and put in 550cc Sard injectors. After changing the afm and resizing injectors on the computer it ran very rich (blowing heaps of black smoke at idle and could smell fuel) however it always started fine and idled. I have only run it like this for a few minutes. So the other day I installed a wide band afr gauge and O2 sensor in the exhaust, since then it won't start at all.
I didn't think I would have touched anything that would effect the car starting while installing the guage, all I did was pick up power and a ground for the new gauge and welded a new bung in the exhaust. The factory O2 sensor has been left untouched apart from cutting off the wire that I had joined to the signal wire to run a crappy narrow band gauge.
I started it up just before putting the gauge in and it ran, then as soon as i tried after nothing.... It just cranks over, I can smell fuel, and if I keep cranking maybe every 15 seconds or so it sort of half fires for a second or two...
I have checked the wiring of the AFM it all seems fine.
If anyone can help me, or point me in the right direction of where to start looking it would be greatly appreciated.
Thanks, Pat.
https://www.sau.com.au/forums/topic/371895-help-with-rb20det-nistune/
Fouled spark plugs.
I was thinking about that, but would it go from idleing fine, not missing or anything to not starting at all? I would have thought it would run a bit rough for a while first? Might pull the plugs and check them...
My mates with rotaries would fould plugs trying to start and flooding it, then it wouldn't even splutter just turned over with nothing. It is easy enough to pull one and see if its black with soot, usually a bit of steel wool on them to brush them clean is all they need.
Cheers for the advice guys, I tried changing over the CAS but still the same problem... I pulled a plug and it was pretty black, it was sparking but very weak spark, so i cleaned it up and the spark was a lot stronger. So I'll clean the rest of them in the morning and see how it goes.
Did you perform a sensor check in Nistune?
Also WRT the richness, did you adjust the injector latency? If the Sards are faster acting than the stockers this could be the problem. The latency adjustment is in a different location to the injector resize function (which doesn't seem like a good idea to me).
Injector resize isnt perfect u still need to log a low load run and tweak the k constant with 02 feedback off an get close to 14.5 then if idle is rich adjust the latency. Then turn the 02 back on when finished
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
