Hey guys,
I've been interested in the Gtr since I heard about it and what it can do.
Im an electrician and am doing my diploma, ive just joined a class called reporting and specs.
I have till November to learn about a topic of interest and present a 3000 word written report and a 12 minute speech.
I also must have to have a target audience
Your idea can be WHAT EVER you want.
I've chosen to present a report to the Europe touring car championship, my report will include trying to organize or ask to let other cars into there tour or try to create a world tour. It's all a bit rough ATM as I've barely thought about it.
I will be basing my idea to the audience on the Gtr (as I've heard it is "faster the the 911 turbo around the Nurbergg ring")
I will also base it on alot more fun and a bigger car scene around the world (seeing as australias only real coverage is bathurst with aus cars)
Amongst other points I have in mind.
My point for this thread is that I'm sure alot of you guys know alot about the Gtr.
My first approach will be getting the manuals of the car
I'll then be looking for sources such as from the makers of how it puts that much power to the wheels
Some people may think this is lame but I think it'll interest me a little while will make me want to do it more
Hoping some people can help me with a manual download or some good websites or books.
Or info on the Europe car scene.
Any help would be great to get this ball rolling.
Jarrad.
https://www.sau.com.au/forums/topic/371918-keen-to-learn-about-the-gtr/
Don't quote Wikipedia as the source. Most claims on Wikipedia are also referenced in the Bibliography at the bottom of each page so if you use something, go straight to the source and have a look for yourself.
Wikipedia is a gold mine for academic research, as long as it's not used as the actual source.
Why don't you do a report on the R35 and the WTAC ?
A couple of threads you can get a lot of info from, including pics, graphs, video's etc. Indepth build threads right here.
Whatever doesn't make sense you can ask the people directly who are involved.
You can even post results.
Your references can be for the std cars mechanics and how altering power, aero etc changes x.y and z.
nah i don't read books to much i only have this one cause a mate gave it to me, i think the most info you will find will be in mags like "wheels" etc, anything that reports on stock cars as they are released, otherwise try the Nissan web site, they might still have a write up on its release or of the updates its had over the last few years.
Spoke to my teacher and he made a good point. It's going to be hard to find info so I guess I'll do something else :S
I thought there'd be stacks of info about it, like a whole walk through of the car and where it competes and everything.
Ohwell solar panels it is lol.
You can use wiki, theres heaps of info as it has already been said just use the wiki resources as reference at the bottom of the page.
I cant see why you couldnt find any info on it :S
i think its just a bit over my head considering its for tafe
thanks alot aaron, ive deciding im going to do a "breifing" about solar energy and try to get some new customers as i work for "joe solar" or something haha, so my main points are going to be why its worth getting, sadly ive relised theyve canned all insentive to get solar and from what ive seen its pretty pointless.
so im gunna struggle to sell it :P
would you agree? seeing as you "were" in the industry? haha
    • Thread bump, again! Although, no bad news this time. Posting for the sake of possible root cause. Basically, I rebuilt it (mostly stock), installed Haltech + sensors, had it running fine on new ECU.  Still not really understanding why it cracked pistons last time. Got to tuners, and while checking timing, noticed +-10deg of timing scatter while revving. Changed CAS, and it was rock solid. While not definitive, can't imagine seeing 20+ psi with that amount of scatter would be a good thing. Also glad I found something.   Bit more of a run down; Carried out a stock rebuild, a set of stock pistons, out of a spare bottom end. Everything stock apart from head studs and oil restrictors. (so I can pretend I didn't let the Nissan out, ha.) Armed with the measuring gear and FSM, set about doing overhaul. Oil restrictors as per oil control thread for a RB25, stock oil pump, drifting. Head drain/vent from rear of head, to passenger side of sump above oil level. Two dash 10 vent lines from drivers side of sump (unused atm) Hi octane style cam cover breather kit Splash covers over last 2 cam caps. Both breather lines from cam covers to vented to atmosphere catch can, not plumbed back into sump (wanted to see what it was actually breathing). Got it run in (did about a 1000km) no to low boost scenario, As I had questions over old ECU setup. Installed haltech +sensors for flex Retune on E85 (finding CAS Issue along the way), made 300rwkw at 20psi, out of wastegate. Did a drift day the next day (yes, it was a big weekend!) and was checking catch can throughout the day, ZERO blowby. I mean nothing. Lines from cam covers are not even wet. Done a bunch of street driving, spirited and catch can is still dry. Early days I guess, but pretty happy so far. Also now run 10w60, up from the 10w40 that I used to run. Oil pressure is significantly better, especially when hot (as you would expect)
    • Thanks buddy. I thought it was a server storage thing. 馃ぃ
    • Perfect! Thanks for this, both look like great options!
    • but deep down inside once you Skyline, you always Skyline
