Hey guys I have a set of tien coilovers in my r33 gtst theyve always been stiff since i got the car. I dont realy know to much obout coilovers but is there a way to soften them up? i know for a fact there is no dampner contril on it there just plain height adjustable coils. Also ive been told that they may be screwed from the previous owner having the car to low but at the same time people have told me that the spring rate is to stiff, like i said dont know much about coils if anywone could give me some useful info id be happy thanks =D
https://www.sau.com.au/forums/topic/371919-stiff-shocks/
piss them off and use bilstein shocks with kings/whiteline or eibach springs. get extra circlip grooves for height adjustment. Or have sleeves fitted to them (ie HSD sleeves) for full height adjustment.
even the basic BC BR coilovers will be better than your Teins (ride quality wise). no doubt your tein's are valved like shit and are probably tired, plus springs rates to suit a jap touge car (much like the Teins I've just filed under B for bin)
I even think Tein super streets are pretty average. I fitted some to a WRX I drove for around 6 months, okay but didnt feel sweet like bilsteins. I also drove a 33 gtst a while back, 4kg springs all round (what they come with) and car felt bouncy and wrong.
to answer your question they are not worth buggering around with unless they are top of the line Tein's, then getting someone like Race Pace to tweak them would be a good option but if they are just HR's or HA's or what ever not worth it IMO.
Cheers, Jack
https://www.sau.com.au/forums/topic/371919-stiff-shocks/#findComment-5929814
If they're not leaking you could think about throwing some softer springs at them and resetting the height to something sensible, but you may then have too much dampening for the spring rate.
Probably better to get a new set. Spring rate is very important. Find out what rate your current springs are (check the sticky, not sure if its still active tho) to give you some perspective on what to go for. Or else find someone with, say, 5 or 6kg front/4kg rear in a brand you can afford and see if you like them.
The bounciness in the ones you tried could have been stuffed shocks or ride height too low causing bottoming out on the bump stops, so if you can, find another 4/4 to try.
https://www.sau.com.au/forums/topic/371919-stiff-shocks/#findComment-5930949
interesting how you got so many responses, ive been struggling with my teins for ages, tossing up wether to get rid of them or change springs, mine are HA and damper adjustable, obviously the springs are very stiff.
Ive decided with mine that i will just put up with a little bouncing here and there, ive set the damper to what i think is ok, dam good on a perfect road, but bit uncomfortable on a rough road, and dangerous on a rough fast road taking corners..
but id rather put that money toward a gt30 than stuff around buying more coilovers, they can be bearable if you can adjust the damper , definitely no good at the drags lol..
ive found they are better when the car is lower rather than higher, the spring is longer if its lower.. correct me if im wrong but thats where ive found it to be best..
if you were in brissy i could show you how mine handles.. but if you cant adjust damper then it could be bit hopeless.
Edited by SliverS2
https://www.sau.com.au/forums/topic/371919-stiff-shocks/#findComment-5932285
Before you dump your shocks go to a Tein dealer and get a price to have them revalved (if in fact it is the shocks that are the problem and not your springs). A proper suspension place should be able to work out the spring rates and tell you if they are too hard.
https://www.sau.com.au/forums/topic/371919-stiff-shocks/#findComment-5932751
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
