This is the BEST security you can have If you love your car then,
Microsensor
2-3 Immobilisers
A second car so you dont drive your baby everywhere and leave it out in the open.
A garage
Incase you dont have a garage, have a bat under your bed and if you hear your car chirp which means someone is near it before they even have a chance to do anything you have your bat ingraved into there forehead.
Maybe you will ave a broken window or a stuffed lock. But no way they taken the car.
Can someone tell me how they will take this car ^^^^ other then putting a gun to someones head.
Break into house while you are using second car.
Find keys in the house since they will most likely be in one of the common locations.
Unlock car.
Open garage.
Drive out.
Most common way cars get stolen. Hence why a hidden fuel pump kill switch is the best option.
Unlock car.
Open garage.
Drive out.
this and a steering lock bar, with the wheels turned so they are pointed towards the kerb, less chance of some one lifting the rear axle and towing your car.
it's bothersome, but i use it if i have to leave the car in a shifty place. Just an extra layer of security thumbsup.gif
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 😛
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
