This is the BEST security you can have If you love your car then,
Microsensor
2-3 Immobilisers
A second car so you dont drive your baby everywhere and leave it out in the open.
A garage
Incase you dont have a garage, have a bat under your bed and if you hear your car chirp which means someone is near it before they even have a chance to do anything you have your bat ingraved into there forehead.
Maybe you will ave a broken window or a stuffed lock. But no way they taken the car.
Can someone tell me how they will take this car ^^^^ other then putting a gun to someones head.
Break into house while you are using second car.
Find keys in the house since they will most likely be in one of the common locations.
Unlock car.
Open garage.
Drive out.
Most common way cars get stolen. Hence why a hidden fuel pump kill switch is the best option.
Unlock car.
Open garage.
Drive out.
this and a steering lock bar, with the wheels turned so they are pointed towards the kerb, less chance of some one lifting the rear axle and towing your car.
it's bothersome, but i use it if i have to leave the car in a shifty place. Just an extra layer of security thumbsup.gif
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
